DIY: How to do coding to disable Start/Stop ECO for dummies
Rating: Thread Rating: 7 votes, 5.00 average.
Old Sep 27, 2024 | 10:31 PM
  #51
JettaRed's Avatar
Veteran: Army
Originally Posted by bluenuys
Anyone have a good source for the Xentry software? Or are we now destined to pay $$ to some guy on youtube to hook us up?
Many folks here have gone with @BenzNinja . He provides XENTRY, DAS, Vediamo, DTS Monaco, WIS/ASRA, EPC and other software on a Windows 10 SSD that you install on your laptop. It's very stable and is installed without kludgy workarounds. With the BenzNinja Club membership, you also get lifetime support via remote connection for any Mercedes you own. If your license or startkey ever gets corrupted, he will restore it. COMAND on my C350 got locked somehow and he was able to get and install a new security code from Mercedes to unlock it. Quite a unique good deal.
Old Sep 28, 2024 | 11:34 AM
  #52
trigital's Avatar
W213 All-terrain
Originally Posted by mbw2020
Have you tried rutracker{dot}org?
AliExpress as well
Old Oct 1, 2024 | 12:41 AM
  #53
Dubai80's Avatar
S560 w222
I got an ssd from aliexpress having all the softwares I need to do everything possible except key programming.
Old Oct 1, 2024 | 12:42 AM
  #54
Dubai80's Avatar
S560 w222
This is a follow up to my previous post in this thread (#20). This time on how to remember last drive mode, e.g. Comfort vs Sport vs Sport+. The steps are 90% the same as the original post so make sure to read it first.
1. When creating a temporary workspace in DTS Monaco use EZS213.smr-d and ESP167.smr-d files.
2. Go to Quick Test, click Start button (near tab's top left corner). Not sure if it is really needed but I
always did it.
3. Next, we need to disable car's firewall. Otherwise variant coding will error out.
4. Go to Diagnostics Services tab. We'll be sending command to car by pressing Transmit button. Watch for
errors in result, at the bottom of the tab. If you get one then you are doing something wrong. Stop.
5. Double click on EZS213 [UDS_CAN_D]. It should change from orange to green.
6. Select EZS213 [UDS_CAN_D] > Session > [10] Extended Start. Press Transmit button (located below the
box where you selected Extended Start).
7. Select EZS213 [UDS_CAN_D]> General Jobs > Security Access Level 3B. Transmit. If no errors, car's
firewall is disabled!
8. EZS213 [UDS_CAN_D] should stay green to the very end, otherwise firewall will be back.
9. Next, we need to enable variant coding. Double click on ESP167[UDS_CAN_D]. It should turn green.
10. Select ESP167 [UDS_CAN_D] > Security Access > [27 08] Request Seed Variant Coding. Transmit. You
should get 8-byte seed value, e.g. B8,28,01,23,42,50,3B,70.
11. Open cmd, run mbseedkey_cli.exe -d C:\MBSeedKey\dlls\CPC_NG_CPC_NG_14_31_11.dll -a 0B -s
B828012342503B70. Copy generated value, e.g. 9F CB EB F6.
12. Back to Monaco. Select ESP167 [UDS_CAN_D] > Security Access > [27 0C] Send Key Variant Coding,
paste the seed key into Seed Key parameter. Transmit. Make sure no errors reported. If no errors, then
variant coding is enabled!
13. Go to Varian Coding tab.
14. Connect to ESP167 [UDS_CAN_D], select [002] MB-Funktionen (Fahrprogramm-Master) Write.
15. SAVE CURRENT DATA!!!
16. Find "LastMode_V2_0" line (byte 60, offset 6). Current value is likely to be "do_not_store". Change it to "store_infinity". Press Do Coding
button. Watch for errors.
17. Back to Diagnostics Services tab.
27. Select ESP167 > Ecu Reset -> [11 01] HardReset Reset. Transmit.
Done!
Thank you, I really needed to know this, after disabling ECO start/stop this will be useful as well since I always keep changing to E when the car starts.
Old Oct 1, 2024 | 04:26 PM
  #55
mbw2020's Avatar
GLC300
I should have probably clarified that you need to do variant coding in Electronic Stability Program ECU. Mine happened to be ESP167_Diag_00A07F per Xentry. Thus use of esp167.smr-d. Interestingly enough, my starting point was ChatGPT. It said that remembering last mode was possible for my car and that it would be somewhere in ESP unit.
Old Oct 2, 2024 | 01:04 AM
  #56
Dubai80's Avatar
S560 w222
ill do it tonight, is there anyway I can get radar sensor parameters for w222 2018 amg kit? One radar is giving misalignment error in xentry. Thought may be it poped up coz I changed my bumpers from chauffeur kit to amg
Old Oct 2, 2024 | 02:22 AM
  #57
trigital's Avatar
W213 All-terrain
If just one radar shows misalignment, maybe is not about parameters.
Old Oct 5, 2024 | 03:17 AM
  #58
san40's Avatar
2015 e63 wagon
I'm reading up on start/stop coding, and found this very useful for coding in vediamo, doesn't look too scary after ILS activation
Old Apr 22, 2025 | 08:27 AM
  #59
GabrielFSousa's Avatar
c205
where i can dowload the DLLs ?
Old Apr 22, 2025 | 08:55 AM
  #60
trigital's Avatar
W213 All-terrain
Here you can calculate at user level, no need to pay anything to anyone...
https://unlockecu.sn.sg/
Old Apr 22, 2025 | 10:52 AM
  #61
c205
you rock, thanks a lot...
how i know what is my ecu ? i have a w205 coupe of 2016 !!
Old Apr 22, 2025 | 10:55 AM
  #62
trigital's Avatar
W213 All-terrain
What do you want to achieve? Start Stop with memory?
Old Apr 22, 2025 | 11:00 AM
  #63
c205
yes, tried med40 and cr43, but the seed i sent is always wrong , maybe because i dont know what ecu i have
i manage to found the dlls, didnt try your site yet
Old Apr 22, 2025 | 11:04 AM
  #64
c205
i dont have the xentry
Old Apr 22, 2025 | 11:10 AM
  #65
c205
Old Apr 22, 2025 | 11:20 AM
  #66
c205
looks like is crd3 ?
Old Apr 22, 2025 | 11:34 AM
  #67
trigital's Avatar
W213 All-terrain
"i have a w205 coupe of 2016 !!" even is it white, or AMG....or even if it have HU,5.5 with a complicated retrofit without any feedback, the most important is the VIN if you don't have Xentry.
Old Apr 22, 2025 | 11:41 AM
  #68
c205
VIN: WDD2053041F346464
Old Apr 22, 2025 | 11:46 AM
  #69
c205
Old Apr 22, 2025 | 11:57 AM
  #70
trigital's Avatar
W213 All-terrain
More likely is crd3s2
Old Apr 22, 2025 | 11:58 AM
  #71
c205
thanks
Old Apr 22, 2025 | 12:09 PM
  #72
c205
seed now was OK.
but had this error messaging
CRD3S2.IMPLICITCODING Schreiben (NRC = 0)
Old Apr 22, 2025 | 12:26 PM
  #73
trigital's Avatar
W213 All-terrain
seed now was OK.
Crd3s2 has 2 levels that need to be unlocked, usually directly from the Routines. Of course, engine stopped, ignition On, enough voltage,....
Old Apr 22, 2025 | 12:27 PM
  #74
c205
how i do the unlock ?
Old Apr 22, 2025 | 12:40 PM
  #75
c205
which option in routunes ?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
