2013 ML350 W166 - HELP! ACCIDENTALLY JUMP START MERCEDES WRONG POLARITY NOWWONT START
Old Feb 10, 2022 | 05:55 PM
SikC63's Avatar
2001 E430, 2014 E 350, 2012 C63 PP30
Guys,
I have a 2013 Mercedes ML350 W166. I accidentally connected the jumper cables incorrectly (from under the hood) after the battery needed some juice. I did not connect the jumper cables to the back battery (located under front passenger seat) but the red cross under the hood. I connected the ground to the red cross and the positive to the ground on the chassis.
Smoke was coming out of the alternator. When I hook up the car to jump start again the car does not start. I think i fried my alternator. What should I look for in diagnosing my issue?
The car seems to turn on accessories but does not wish to start.
Thank you for your time.
Old Feb 11, 2022 | 05:06 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
$$ouch$$
Unfortunately there is no single protection against a polarity reversal.
Alternators use an AC/DC rectifier bridge built around 6 high Amp diodes plus a voltage controller. This is the prime candidate for any short-circuit.
1- Single out shorted circuits:
> Go ahead and disconnect ALT as well as 100% everything else directly at the PREFUSE power dispatch.
> Next reconnect one circuit at a time. The branches that feed shorted modules will draw high current.
2- Guess at non-responsive circuits:
> List SAM's fuses poped by shorted units. Exploded modules will remain silent
> Hook up a scanner to enumerate live modules. Trace circuits power with DVM.
Good luck for a low count of casualties
Old Feb 11, 2022 | 07:12 AM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by SikC63
Guys,
Sorry to hear.
Buy a scanner, read codes.
Carefully go through the fuse box in the engine bay and replace what needs replacing.
Clear codes.
Repeat the process over and over until you find the bigger problems like potentially fried alternator.
Check battery positive cable carefully.
Old Feb 11, 2022 | 07:57 PM
SikC63's Avatar
Where do I find the SAM Modules? Also is there a wiring diagram I can refer to? Alternator is definitely F****
Old Feb 11, 2022 | 09:01 PM
progressing...
With the ALT disconnected do you still have any remaining shorts ?
Both SAM'S modules act as "Fuse holders & Pwr Mgr". They are located in:
- driver side engine bay (90% chance shot)
- passenger side trunk side liner (50% chance...)
Front SAM also controls the K57 main relay within PreFuse enclosure. It's a VIP computer acting as the ECU's butler for some peripherals... (Main Batt LIN Sensor)
Wiring diagrams are available in eBay shareware DVD or directly by online subscription sces (AllData, Mitchell,...)
Have a look at FCP Euro for sweet deals on your ALT & more...
Old Feb 17, 2022 | 11:32 AM
streborx's Avatar
Top Answer: 1
G550
Get yourself a set of polarity protected jumper cables for next time.
Amazon Amazon
