COMAND SHUTTING DOWN
Things my husband has tried from various internet searches
- removing some fuse (not sure which one) and waiting for a while then putting fuse back in (nothing)
- Replaced main battery (nothing)
- reset by holding the eject disc for 10 seconds - can see and hear a reset, but still same message COMAND shutting down after it powers back up, (so still nothing)
- removing plug to satellite radio under floorboard in rear cargo area (THIS WORKED BY KEEPING COMAND SYSTEM SCREEN ON *BUT* NO AUDIO whatsoever - tried radio, bluetooth, making a call, etc and no audio.
- It's worth noting that trying to save any audio preferences e.g. surround sound to on vs off does not save. Also dash not dimming with scrolly-wheel near headlight settings either.
HELP?!
It may be an easy fix but not simple to figure out or it may be a $2500 unit plus 2Hrs of labor.
Changing the battery was a good call because it could well be a low-voltage "consumers Off" protection.
> Make sure the cabin filter is either newish or removed to allow good air flow to circulate through Comand and Display.
These are heat generating units that rely on inner dash venting. Filter Access located in passenger footwell. Easy hack with YouTube search skills.
I don't suppose you care to learn "ODBC Scanning" skills for the next step ??
I realize this may end up going back to the dealer for a pricey fix, but I have to admit I was really hoping from their initial diag test, it would have turned out to be some sort of system software update. Instead, I quickly got cold feet when I received the quote from the dealership, especially with such limited communication between myself and the tech (have to go through middleman in office). This is likely because I do in fact have a local mechanic who I truly trust and has done the regular maintenance and even repairs to my last 4 cars including two mercedes ranging from minor issues with the MB's to electrical issues in an old jeep. Luckily he treats me extremely fair on diagnostic stuff, so my gut instinct was to have him see if he can work any magic - he said to swing it by his shop tomorrow morning. If not, I'll be slowly (and quietly, aside from my crying) driving back to the dealer
And yes, admittedly I am a fan of DIY where at all possible (ha!). So today, i'll try the cabin filter thing. And any ODBC scanning skillz you can offer! THANK YOU
The audio system involved here is not trivial, it runs a "MOST Network", a fine German creation. The head unit is not easily serviceable either...
So before you realize, you could find yourself in deep-waters -or perhaps not if you're lucky.
Get a $150 iCarsoft or Autel scanner on Amazon prime to see what it says. If not 100% useful now, it will be next time for sure to give you heads-up.
Scanner are a bit like a MD stethoscope: you don't become a heart surgeon just with the tool alone. Youtube + practice + forum search!!!
Knowing what fault code is active tends to keep the Sce Advisor confusing games dialed down a notch.
HELP?!
Hope that helps!
ANY DETAILS OR MORE EXACT DESCRIPTION WOULD HELP.
THANK YOU!!
