W210 red & green security lights flashing?
W210 (1996 E320) white
'96 W210 (E320) has both red & green security lights flashing for about 30 seconds after locking or unlocking with the remote. Did a search, replaced the batteries with new, resynched the remote both ways (as the instructions in the manual and the posts on the board) but they both still flash. Any help appreciated, thanks!
-Tom
-Tom
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Do you have another remote to try? I bet that it will be a problem with that one remote.
Also, where did you get the batteries? Were they fresh?
-s-
-s-
As luck would have it, the other remote broke last month.
The batteries are new from WalMart and test out to their nominal voltage.
Any other info greatly appreciated!
I just looked it up.
The service information states:
Green and red alternating: No engine control enable
Green and red simultaneously: Transmitter battery voltage too low
With new batteries, if the voltage is too low, the battery contacts may be dirty. If the lights are alternating, there's another problem (and it says to do "test step 7 of function check" which I won't look into until you state which pattern you have...)
-s-
-s-
Simultaneously.
I guess I need to buy a couple (more) new batteries and see...
Scorchie, thanks for your help,
-Tom
-Tom
2004 E500
Originally Posted by aTOMic
Simultaneously.
-Tom
-Tom
Originally Posted by BoSoxFan
When I used to work a lot with electronics, I would use a pencil eraser to remove the oxidation from a contact. Use a can of compressed air to remove any eraser shavings or residue. The bent leaf type springs can break very easily though so be careful (I don't know what kind of contacts are in these remotes). There are also contact cleaners sold in spray bottles which you can get in any electronics shop. They're better for removing dirt or dust than oxidation though.
-s-
2004 E500
Originally Posted by scorchie
Agreed, but I always use the pencil eraser like you suggested! I don't rub it back and forth, just in one direction.
-s-
-s-
