Mercedes Download Manager (DLM) installer
Old Feb 24, 2025 | 08:10 AM
Myaser's Avatar
Please
Can you upload the file again please
Old Feb 24, 2025 | 09:46 AM
Myaser's Avatar
Originally Posted by trigital
Hello can you upload it again please I have NTG 7
Old Feb 25, 2025 | 04:41 AM
trigital's Avatar
W213 All-terrain
Try here:
https://easyupload.io/jt133z
Old Feb 25, 2025 | 06:06 AM
Myaser's Avatar
Thank you
THANK YOU VERY MUCH SIR I got it
Old Mar 14, 2025 | 06:19 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Hello,
I have a USA Spec, 2018 W222 S63 Sedan. My current map version is 2023 V25.0 N. America. I have NTG 5.5. Can you provide me the new map update?
Old Mar 14, 2025 | 06:22 PM
trigital's Avatar
W213 All-terrain
Sure, choose from DLM the desired version and post or PM the VIN number.
Old Mar 14, 2025 | 06:33 PM
  #32
trigital's Avatar
W213 All-terrain
This is your Activation Code for North America V28
NNRJM4
USB2.0 formated NTFS for loading the Maps on USB from DLM.
Old Mar 14, 2025 | 07:40 PM
  #33
Top Answer: 1
For some reason it won't let me download anything. At first it said there wasn't enought space on the USB drive, and now it is saying the USB is not writeable. This is the same USB that I used for my previous version. I removed it and reformatted the USB drive. What do I need to do differently?
Old Mar 14, 2025 | 08:11 PM
  #34
trigital's Avatar
W213 All-terrain
I don't know, maybe the message is refering to missing space on your laptop,
Anyway, first step is formatting....
You can try another USB also
Old Mar 17, 2025 | 05:50 PM
  #35
alnemir's Avatar
2023 EQE 350 SUV 4Matic
Hello,
I'm in FL USA, retired 9/11 first responder in New York, recently acquired a used 2023 EQE 350 SUV. It has 2022 North America with 2024 CA somehow, but here in Florida it won't show even 50-60 years old state roads. Following your posts I downloaded the DLM installer and the North America V.21.0 maps. I understand that during installation it will require an activation code. Any chance you can supply me with one? I just afraid that I will pay the subscription and the maps won't show these FL state roads as well.
Thank You in advance
Old Mar 17, 2025 | 05:52 PM
  #36
trigital's Avatar
W213 All-terrain
You should have 3 years free update. Try to start the update.
Anyway, my Activation Codes are available till NTG5.5..
Old Mar 17, 2025 | 06:07 PM
  #37
alnemir's Avatar
MB customer service says 1 year since 2023. Will I lose my 2022 maps if I start the download and have no code?
Thank You
Old Mar 17, 2025 | 06:10 PM
  #38
trigital's Avatar
W213 All-terrain
Never tried to "try", here in the EU the "3 Years Free Map Update" is an option and is present on car Data Card ( VIN decode).
Old Mar 18, 2025 | 04:33 PM
  #39
Top Answer: 1
Thanks for everything. I had to use my old laptop, which is the one I used for the previous update. It worked with the original USB stick. I got it downloaded and it's currently updatin the Nav system in my car right now. It takes a few hours, I'm at 55% after about 90 minutes of driving.
Thanks a bunch!!
Old Mar 18, 2025 | 04:43 PM
  #40
superswiss's Avatar
2019 C63CS
The Download Manager needs sufficient storage on the local hard drive to temporarily store the downloaded files before they get copied to the external media. If I remember correctly, in the settings of the Download Manager you can configure the path for the temporary download location, so make sure it's pointing to a location with sufficient free space.
Old Mar 22, 2025 | 07:51 PM
  #41
ryancolebourn's Avatar
2018 S560
Originally Posted by carlosinseattle
Hello,
I have a 2018 S560 and am searching for the latest map update too. If anyone can provide it, it would be greatly appreciated.
Old Mar 23, 2025 | 04:56 AM
  #42
trigital's Avatar
W213 All-terrain
You could find in post #28
Old Mar 23, 2025 | 09:52 AM
  #43
alnemir's Avatar
Activation code for my installed map
Hello,
Is it possible to find out the activation code for the currently installed map? I'm the second owner of 2023 EQE 350 SUV
Old Mar 23, 2025 | 10:00 AM
  #44
trigital's Avatar
W213 All-terrain
Originally Posted by alnemir
Hello,
Why you need Activation code for an already installed Maps?
Old Mar 23, 2025 | 10:02 AM
  #45
alnemir's Avatar
In order to try the trick: replace the memory stick & install a new map
Old Mar 23, 2025 | 10:03 AM
  #46
trigital's Avatar
W213 All-terrain
This trick is not available anymore even for older models.
The activation code for your current installed map is free on any dealership
Old Mar 23, 2025 | 09:33 PM
  #47
2018 S560
Hi trigital. I went to link in post 28 and downloaded the download manager. Then in download manager I successfully downloaded NTG7 to an SD card via a USB adapter only because I don't currently have a large enough USB drive. I did not expect it to work in my car since download manager and many posts say it must be USB2.0 only, but I gave it a try and as expected when I put the SD card in the car nothing happened. But if I get a large enough USB drive and download NTG7 to it, should it then work in my car? Also should I not be trying NTG7 and should only be trying up to NTG5.5? Thank you so much for the help! Ryan.
Update: I put NTG5.5 on the SD card and now the car recognizes it and asks me for the license key. I thought I saw the license key somewhere here before but I can’t seem to find it now. I’m reading the license keys are VIN specific, so seeming like I will need a key generated for my VIN?
Old Mar 24, 2025 | 10:00 AM
  #48
trigital's Avatar
W213 All-terrain
So your car has NTG5.5, yes? Post the VIN, Region, MAP version and I will generate the Activation code.
Old Mar 24, 2025 | 07:47 PM
  #49
2018 S560
Yes, NTG5.5
VIN is: WDDUG8GB4JA415780
Region: North America (US)
Version: V28.0
Thank you!
Old Mar 24, 2025 | 08:00 PM
  #50
trigital's Avatar
W213 All-terrain
Yes, NTG5.5
Version: V28.0
Thank you!
I would try :
MIYF3O
