E450(12v) under-charging? parasitic loads?
Old Mar 6, 2025 | 08:54 AM
dsmithlib's Avatar
2025 E450
Exclamation E450(12v) under-charging? parasitic loads?
Hello, I have recently taken delivery of my first MB, a beautiful E450. However, I have found that the charging system seems to leave the 12V AGM battery significantly undercharged. I have a pretty good understanding of both batteries and charging systems. I am aware that some manufacturers reduced alternator output for various reasons. And, this is my wife's car that is generally driven about 10-15 minutes per start - but that is how she uses it. I have not found that longer drives improve the situation much. We recently began receiving app updates that the battery was low and I then had trouble getting it take a charge.
Details: The battery is rated 80ah. I have metering for my charger that accumulates how much is output per charge. When I put the charger on day after day, it routinely reports about a 20ah (equivalent) charge. Now, I do not expect that E450 or any car would do a full charge like a battery charger. If I charge once every two weeks, it will take 30ah+.
This is two problems. First, it is not good maintenance of the AGM battery and I would be replacing it often. Second, this highly electric vehicle is going to leave me stranded in a parking lot one day needing a charge.
I have joined the forum hoping that someone can shine a light on this issue. Does the MB system permit tweaks for charging rates and thresholds? Are there perpetual loads on the system that I should disable.
This has taken some time to understand and is killing the joy of this new car experience.
Thanks,
Old Mar 6, 2025 | 03:39 PM
W205C43PFL's Avatar
Thanks,
You posted in the generic sub-forum, I mean that is fine but I am worried that people that might not see your thread, I recommend posting in the sub-forum that corresponds to your model.
Old Mar 6, 2025 | 03:40 PM
W205C43PFL's Avatar
Here is the sub-forum that corresponds to the 2025 E 450 https://mbworld.org/forums/e-class-w214-284/
Old Mar 6, 2025 | 07:31 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
low voltage... chaos is next!!
Thanks,
This is very perceptive of you. I went through a similar reality check after taking delivery of my new Benz... low voltage chaos is a design feature
Low battery charge and drain while parked are amazin' on factory-new cars... more recently we've come to realize poor voltage affects basic engine performance in addition to seeding CAN modules chaos.
Unstable voltage are proven to detunes a collection of MB platforms.
Is your 12V AGM battery charged by a conventional alternator or from the 3-Phase AC traction generator?
