XENTRY TCU Adaptation Screen
Old May 2, 2025 | 08:55 AM
sprfrkr's Avatar
E350, W140 S, C63, G55, 420SEL, Prius, Dune Buggy, Ducati
I am in the "Performing Adaptation" screen in XENTRY. I can't tell if this is the screen that actually performs the adaptations or not. If it is, do I simply drive around with this screen up?
https://cimg1.ibsrv.net/gimg/www.mbw...ae379072f.jpeg
[img alt="Adaptation
"]https://cimg1.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/tcu_cc35df6911d806a7ff6997c339fdb23ae379072f.jpeg[/img]
Old May 2, 2025 | 09:06 AM
JettaRed's Avatar
Veteran: Army
Old May 2, 2025 | 09:07 AM
JettaRed's Avatar
Veteran: Army
There are other videos if you search for them on YouTube.
Old May 2, 2025 | 09:10 AM
JettaRed's Avatar
Veteran: Army
By the way, you are actually using DAS, not XENTRY. You must have an older car.
Old May 2, 2025 | 12:55 PM
sprfrkr's Avatar
Thank you. Yes, a 2007 G55. The video above is for the Torque Converter. I searched, but could not find the other one.
Old May 2, 2025 | 02:21 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
IMPROVING TRANNY SHIFTS
Why are you retraining your TCU adaptations ???
Normally Tranny learns to shift EXTREMELY WELL BY ITSELF else other factors from engine side are involved to deliver poor shifts.
-- ATF viscosity needs to be near factory conditions for TCU to work within range.
-- Start with a chassis reboot + good stable voltage for effective CAN networking between ECU <--> TCU.
-- Engine throttle needs to be predictable without any misfirings.
Old May 2, 2025 | 02:55 PM
sprfrkr's Avatar
New Valve Body, Conductor Plate, solenoids, etc. Purchased as a single reconditioned piece from MB.
Old May 2, 2025 | 03:14 PM
NEW PARTS INSTALL
yes, you do have too adapt virgin hardware.
No two ways.
Old May 2, 2025 | 05:15 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Is this 722.9 or 722.6 transmission??
Old May 2, 2025 | 08:24 PM
sprfrkr's Avatar
722.6
Old May 8, 2025 | 05:05 PM
MBENZTECH's Avatar
Ok. Well for the 722.6 transmission, there is no upshift and downshift adaptations screens or procedures like the 722.9. So what we did for those, is reset adaptations and then went for a drive. If there was any gear that is not smooth, you drive the car in that gear and shift manually between 2000 and 3000 rpms. The transmission control module for the 722.6 is outside of the transmission. The TCU for the 722.9 seats on top of the valve body and this one needs programming, coding, personalization and range sensor calibration.
Old May 9, 2025 | 08:59 AM
JettaRed's Avatar
Veteran: Army
Really makes you wonder if newer means better.
Old May 11, 2025 | 05:08 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I've come to the conclusion, that if you DIY forget anything that doesn't have a 722.6 transmission
and any engine after 2005 and also forget the M271.
So M111, M112, and same period V8's.
