OM642 350 Bluetec oil leak top of the engine
Old May 26, 2025 | 04:30 AM
KikoUK's Avatar
W221 2013 Bluetec
My 2013 W221 diesel has developed an oil leak at the top of the engine. Majority of the oil seems to be near the right hand side of the turbo when you look at it from the front.
Oil seems to be squirting up from somewhere as the oil is on the lining of the plastic cover that needs to be removed to access the engine, as well as at the very back of the bonnet lining, and it's dripping down to the area in the attached photo.
The V was inspected and the bottom of the engine is bone dry. The turbo, pcv and the 2 charge pipe seals were changed but the oil is still squirting up/sideways
from somewhere. No related errors thrown when scanned.
There is a little oil puddle in the area circled in white and the oil is generally in the area marked with red.
Any help or ideas where this could be coming from? Car is on 125k miles
TIA
Old May 26, 2025 | 09:16 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
CRANKCASE PRESSURE RELIEF
Your turbo diesel OM642 has a new PCV and is still squirting oil from engine top.
You're gonna need to do some research either elbow deep in oil or with your keyboard...
Your crankcase pressure needs relief to vent out of the engine.
The weakest seal gets breached! It's better to have a dirty comestic leak than popping a rear main seal.
Help your engine vent less or better rather than plugging up new seals.
> Find out exactly what part of your pcv was replaced then look up part diagram for additional conduit that were left original and may well be jammed plugged by hard sludge.
> See how much crankcase pressure do you get at idle...
> PCV has both inlet and outlet. Once satisfied with outlet go for inlet.
Old May 27, 2025 | 04:39 AM
KikoUK's Avatar
W221 2013 Bluetec
Hi and thank you for your reply.
These 3 seals were changed. The pcv seal is the small brown one in the photo, however, the oil squirt issue was preexisting way before we changed the pcv seal. So I don't think the oil leak is related to the pcv
Old May 27, 2025 | 04:31 PM
the oil leak is related to crankcase pressure relieving out - Help PCV vent out.
Old May 27, 2025 | 06:13 PM
KikoUK's Avatar
W221 2013 Bluetec
Do you mean that the oil leak is from the PCV valve? The PCV valve is on the other side of the turbo and there is no oil there
Old May 27, 2025 | 09:20 PM
PCV reliefs crankcase pressure... when it's not working well every gasket vents out.
Look at mbparts catalog to pick your engine spares.
