2013 G63 AMG Engine Knock?
Is this standard VVT rattle or bend/loose rod knock?
Bore scope cylinders walls for impacts.
Visually inspect oil filter for light metals.
What I hear sounds like my m157 and normal
but I know that if I was sitting there in front of the engine while it was running, I may be able to hear a knock that I'm not able to hear based on your recording.
can you get an audio clip with the hood open from outside the car near the engine bay and can you also get a video clip from the exhaust side just in case this is a misfire you're hearing?
clip of normal m157:
https://mbworld.org/forums/ml63-amg-...ml#post8671917
clip of real knock on m157:
https://mbworld.org/forums/w212-amg/...ml#post8143581
another clip:
clip of misfire that is mistaken for bottom engine issue:
https://mbworld.org/forums/w212-amg/...h-exhaust.html
now that you own an M157 engine, you should take a look at this sticky (above clips are all from the sticky)
https://mbworld.org/forums/w212-amg/...fixes-diy.html
