Mercedes GL450 ECU
Old Nov 1, 2025 | 01:42 AM
quick-tire's Avatar
gl450
Question Mercedes GL450 ECU
Hello everybody
I have a 2008 Mercedes GL450, and I've had my engine rebuilt at a shop, and they managed to fry my ECU. They told me that they're gonna get me a new ECU, and I said ok. After a year or so I discovered that the ECU they got me wasn't for my car, and they somehow got the car started with it. After a year, the car started running significantly worse. Until last month, the car turned into a crank, then started for a couple of seconds, then died, and each time I tried again, it got worse until it became a crank no start with backfire while cranking. When I scan the codes, the only code I was getting was P0607 module performance. I took it to a shop, and they said that the ECU is not for the car, and it is the problem, and I need a new ECU. I bought a junkyard one from eBay, and it'll be here in a day or two. I want to know if I bought a cheap scan tool with a budget of 500$, can I program the ECU myself? Did this story make sense, and is the ECU really the problem here?
Old Nov 1, 2025 | 02:57 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
FRIED ECU REPLACEMENT
Originally Posted by quick-tire
Hello everybody
Programming a used ECU all the way from scratch is not a casual 1-2-3-task like transferring used ECU coding into a replacement.
Contact forum expert @BenzNinja to finally get your coding done professionally.
The condition that fried prior ECU and that is causing current "crank-no start" issue can also get diagnosed by @BenzNinja ... (perhaps a fuel pump low pressure or ignition fuse ??)
Old Nov 1, 2025 | 10:11 PM
Alexie's Avatar
Hello everybody
No, you cannot program that ECU yourself with a $500 scan tool. It requires specialized Mercedes software like DAS or Vediamo that only professional shops have. The security coding to pair it to your car is a dealer-level job.
Your story makes perfect sense. A wrong ECU will cause exactly the problems you described. The junkyard ECU is the right first step, but you will need a qualified Mercedes specialist to program and install it for you. Don't waste your money on a cheap scanner.
Old Nov 1, 2025 | 10:33 PM
TimC300's Avatar
Strange that it was seemingly working fine for a year until now. Looking up the P0607 code its showing three scenarios. Two say replace ECU and the third shows all types of testing.
Heres a link to the online manual I was looking thru: https://charm.li/Mercedes%20Benz/200...d%20Diagnosis/
For info on the ECU go to Powertrain management > Computers and control systems > Engine control module. There a some TSB's though they may not apply to your situation.
For the codes go to the top selection A L L Diagnostic Trouble Codes (DTC).
I never programed or reprogramed anything before.
