w124 e320 climate control issues
here is my issue and i hope someone can help .
my e320 has been having a following climate control issue .
when its turned on , it will work fine, brings the temperature to what its set to but fan keeps going and wont change speed ( wont slow down or shut off ) but!! its not the case every time . randomly it starts working fine , and then its back to its old self .
i dug in to it , so far i tested blower motor which works fine, ait sampler motor was not turning off due to bad resistor ( replaced it so it runs now) , i had a luxury of being able to borrow numerous climate control panels from a shop and none of them made a difference .
after i put a new sampler motor in today , it worked great for about 45 minutes before i shut the ignition off, then it went back to its old seld . keeps trying to mix hot air with cold and keeps blowing air at high speed continuesly .
has anyone had this issue before ? any ideas what to look in to ? i tried to look at all available information online but i got nothing . i cant be the only one with this problem . any help would be appriciated !!
thanks in advance !!
The main issue is the lack of OBD live data to troubleshoot 1994 chassis.
Based on your work and inputs, remaining culprits may be...
- cabin filter air flow
- blending door flap module
- rotary sensor fan stuck
- low or high refrigerant pressure
- marginal local GND or +12V circuit
I absolutely hate replacing parts blindly because of low success rate.
My top guess would be a bad sensor because it is nearly working well.
Try to force select top side output to see if footwell gas the standard broken sensor...
Happy Holidays to you...
).ill post the outcome after resistor is installed .
Do you have a hot water valve to the heater core? They routinely to fail stuck halfway.
The resistor ladder increasingly drops voltage to the motor. Make sure the motor plug is not toasted and again that you have good GND/PWR using a DVMeter. This is 10+Amps circuit... high power.
Climate control is mandatory function for winter driving else the windshield fogs up on the inside.
Manual operation is better than nothing.
thanks for your help !
