2021 GLE 350 code P0191
Old Jan 6, 2026 | 07:52 AM
dzonen's Avatar
Hi All............wife's 2021 GLE 350 just threw a check engine light with code P0191. Car is in limp mode. That code references a Fuel Rail Pressure Sensor fault. Anyone have experience with this before? Any help is appreciated.
I can find a part # for a Fuel Pressure Sensor that sits on top of the Fuel Pump, but cant find anything about a sensor on the fuel rails. Very little info available for this particular model.
1) is anyone aware of a fuel pressure sensor on the fuel rails? If so, do you know the part # and location?
2) how accessible is the fuel pump? Ive seen several other MB models have the pump under the rear seat. Does the same apply here?
Im more of a DIY guy, so would like to replace the sensor myself if possible vs taking it to the dealer. The sensor is only $60.
Thanks in advance
David
David
Old Jan 6, 2026 | 02:05 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Thanks in advance
David
l
David
David, this 350 is a direct-injected gasoline engine, right?
There are two distinct fuel circuits: low presure then high pressure.
Your fuel rail sensor is located under the intake plenum where the fuel rail feeds the set of injectors.
Old Jan 6, 2026 | 02:34 PM
dzonen's Avatar
Thank you. Do you know if the correct part # for the sensor is 256-905-02-00? I couldnt find any of the MB parts websites with a diagram.
Old Jan 6, 2026 | 03:37 PM
I'm not a part-search guy...
Bosch makes it
Bosch makes this
Use your VIN# for an exact P/N match then find a nearby supplier.
Old Jan 6, 2026 | 08:04 PM
et3surge's Avatar
2002 E320
Fuel rail sensor
Hey I don’t know how different yours is but mine 2016 is on the drivers side rail, under the manifold cover but you can see it without removing the cover. It’s on the aft end of the rail (closer to window).
That looks like my sensor but call FCP Euro, they’ll get you sorted on part numbers. They may even have a diagram.
my HPFP is opposite corner/passenger also closer to the window on the top corner of the engine.
Old Jan 6, 2026 | 08:38 PM
Yes this it.
These sensors get baked by heat soaks at engine stops just like the A/C refrigerant sensor at radiator/condenser base.
For good measure make sure LPFP is ok and not causing HPFP to actup!!
Old Jan 8, 2026 | 01:03 PM
dzonen's Avatar
Thank you. FCP Euro was a huge help. Ordered the part and they got me diagram of the location. Hopefully this solves the issue.
Old Jan 11, 2026 | 07:04 PM
wirelessG's Avatar
e55
Did you get it fixed? I just got this ode this morning literally after packing the car about to go on a road trip with fam
Day before car was extremely low on gas but didn't run out. I also got a drive thru car wash . Hopefully not expensive fix.
Old Jan 11, 2026 | 07:43 PM
dzonen's Avatar
Not yet. I ordered the sensor but hasn't come yet. FCP Euro advised that if the sensor doesn't fix it, it's most likely the high pressure fuel pump that's causing the code.
As a temporary fix, if you have a scanner and can clear the code, it removes the CEL and takes the car out limp mode for a week or so. It does come back and you can clear again until you get it fixed.
Old Jan 12, 2026 | 12:04 PM
wirelessG's Avatar
e55
So driving as is does not harm the vehicle after clearing the code?
Old Jan 12, 2026 | 03:59 PM
No Wet Finger
sensor vs. pump...
use your scanner to diagnose the fuel pressure reported by the ECU.
Old Jan 14, 2026 | 01:19 AM
wirelessG's Avatar
e55
Tried clearing the codes with my Amazon scanner, no go. Towed the car to the mechanic and funny enough, my battery was the culprit. A few theories on the cause of that code, but the battery was checked and indeed low/dying. Replaced the battery and clearing the codes resolved the issue, for now at least.
Old Jan 14, 2026 | 05:23 AM
Lets all hope this issue stays fixed with a fresh battery....
Old Jan 14, 2026 | 10:12 PM
wirelessG's Avatar
e55
Spent $530 on battery and labor.. it better fix the issue.. lol only had the car for 8 months.
Old May 10, 2026 | 07:16 PM
Amg4Lyfe's Avatar
Hey, I just replaced my battery after this error code popped up. I had a feeling my battery was dying since I would get low battery signs for a month or so. Did changing the battery fully resolve your issue? I cleared the codes after changing the battery, so how long would I be able to tell that this resolved the issue? (Going out of the state with the car in a couple of days, so I do not want to risk it)
