Key Fob Resync
Old Apr 8, 2026 | 02:20 PM
Zoskie's Avatar
Key Fob Resync
Can anyone advise the step by step process of resyncing a key fob after replacing the battery? As far as I'm aware, it's the correct battery type and also installed correctly however I'm unable to lock/unlock the vehicle.
I have a C300 Sport with stop/start button (so not able to insert key into ignition like most online comments advise).
Thanks in advance!
Old Apr 8, 2026 | 03:09 PM
W205C43PFL's Avatar
Thanks in advance!
Hmmm it should be automatic though.
Old Apr 8, 2026 | 06:10 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
that is right. Absolutely No syncing necessary after coin cell renewal - Not upside down, right?
Problem must be elsewhere... like unstable Keyless noGo ?
Beware of battery "drain by parking" when keyless gets sleepless.
Old Apr 8, 2026 | 07:34 PM
W205C43PFL's Avatar
I wonder if it is a bad battery even though OP said it is a new one. Old batteries may get old after all even just stored on the shelf and it might also be defective to begin with.
Old Apr 8, 2026 | 07:37 PM
W205C43PFL's Avatar
OP, different model but same idea I guess similar keyfob: https://mbworld.org/forums/c-class-w...ml#post8959680
Old Apr 8, 2026 | 08:12 PM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
Yes it sounds like a battery coating or bad battery. It should not need any relearn off the fob just too replace the battery so at least the problem sounds like a easy fix.
Old Apr 12, 2026 | 11:04 AM
W205C43PFL's Avatar
OP, link to another forum member post: https://mbworld.org/forums/w212-amg/...ml#post9280325
Try this process and see if anything helps.
Old Apr 15, 2026 | 03:05 PM
W205C43PFL's Avatar
OP, did you solve the issue?
