Hi all,
I'm dealing with a puzzling no-start situation on an Infiniti Q50 fitted with the Mercedes OM651 diesel engine and hoping someone here has seen something similar.
The symptoms: The engine cranks but will not fire. Pulling fault codes gives a P0341 — crankshaft position sensor signal out of range or out of sync with the camshaft sensor.
The strange part: When I physically disconnect the crankshaft position sensor, the engine starts and runs. The moment it's plugged back in, no start.
This points to a signal conflict rather than a simple sensor failure — the ECU seems to be getting confused by what the CKP is reporting rather than helped by it.
What I've checked so far:
The issue came after replacing the clutch and flywheel...
Any leads appreciated.
Morgan
- Replaced both the crankshaft and camshaft position sensors — problem unchanged
- Sensor wiring continuity — within spec
- No obvious damage to the reluctor ring
- No other fault codes active
Morgan
CaliBenzDriver
close
- Join DateApr 2019
- LocationSilicon Valley
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveW212 MY'14 M276-3.5NA @75kMi
Liked:6,803 Times in 4,786 Posts
Morgan
You have this almost solved : replacing your flywheel caused CKP correlation issue with camshaft. Originally Posted by mgiberland
Hi all,I'm dealing with a puzzling no-start situation on an Infiniti Q50 fitted with the Mercedes OM651 diesel engine and hoping someone here has seen something similar.
Morgan
How is the special notch identifier set in relation to engine TDC1 ?
The flywheel is not all identical teeth... there's a patern the ECU syncs with camshaft position.
Nothing points to bad/open wiring harness only bad timings to sync your diesel injectors.
trigital
close
- Join DateDec 2011
- LocationSpain UTC/GMT +2 hours
- Vehicle(s) I driveW213 All-terrain
Liked:490 Times in 414 Posts
If you will change your streched timming chain with a new one everything will be OK.
