ML 63 with 22' Rims and 305 Tire
Brabus K3
Hello,
I have right now on a ML 63 10J*20 ET46 with 295/40 R20
Can I intall Brabus VI 10J*22 ET40 with 305/30 R22 ? Will the tire rub somewhere?
Best Regards and THANKS !!!
Ruben.
Ruben.
You are supposed to use a 295./35-22 not a 30, your crazy if you do. The Brabus Car uses a 35
Brabus K3
Your tire sidewall height will drop from 4.7 inches to 3.5 inches ( same as on a Porsche 997 with 19 " wheel option ! ) , supporting a 5000 lb plus 500 hp vehicle and add in weight of additional 5 passengers and luggage . Wouldn't want to be riding in this rig a 115 degree day at 100 mph going to Vegas in the summer !
Brabus K3
This is the size that Brabus suggest me: 285/30 ZR 22-101W
Originals are: 295/45 R19 with 29.5 in of diameter
295/30 R22 have 29.0 in of diameter; this is 1.6% too fast.
295/35 R22 have 30.1 in of diameter; this is 2.3% too slow.
Don't focus just on overall tire diameter - look at the sidewall height from a personal safety standpoint ( and damage to wheel from even a minor pothole ) . Otherwise you could theoretically fit a 26 inch wheel with 1.7 inches of sidewall , essentially just tread , lol !
well at least you have 4.1 " of sidewall ( oem is 4.7" ). Tire sidewall acts as a " spring ", too. Too short a sidewall will increase ride harshness on such a heavy truck- you don't want look good passing strangers and feel like you are riding a wheel barrel !
When it comes to Wheel and Tire Pakages, Brabus Has Always been a little Conservative With Width. 295,35,22 Would and will be the best way to go.
I personally will probably do a 24 on mine With a 295,35,24
By the way Make sure you get three piece wheels for it, Other wise the heavy one piecers are gonna slow this beast down.
Good Luck
Good Luck
