ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
21" wheels
Old Jul 3, 2007 | 11:43 PM
slawek's Avatar
21" wheels
Do you think the new 21” wheels from AMG, used on R63 can work for ML?
Old Jul 5, 2007 | 05:21 PM
StealthAuto's Avatar
Cobra/E55
I myself am not sure, sorry.
Bump for ya!
Old Jul 6, 2007 | 07:26 AM
alroumi's Avatar
G55, G500 & SLK55
I assume they would work but the tyres have to go.
Old Jul 15, 2007 | 12:50 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
i believe the offsets are the same...
Old Jul 15, 2007 | 11:18 PM
slawek's Avatar
This is the 21” AMG wheel I was talking about.
Attached Thumbnails 21" wheels-pkw_mercedes_amg_r63_01_08.jpg   21" wheels-pkw_mercedes_amg_r63_01_09.jpg
Old Jul 16, 2007 | 08:39 AM
v8plus4's Avatar
2024 AMG G63, 2023 Bentley GTC Speed
These wheels would look good on the ML, but they have different offsets. Not sure they will work.
The stock wheel in the US is an AMG Style VI, 10 x 20 ET46.
The R-Class wheel pictured is AMG Style III, 9 x 21 ET60 (front); 9 x 21 ET48 (rear).
Old Jul 16, 2007 | 09:01 PM
slawek's Avatar
Thanks for the fifo ,you probably right on the offset, to bad
Old Aug 7, 2007 | 05:54 PM
Archaedus's Avatar
I believe the new 08' GL550 comes with 21" AMG wheels as well. Though dont quote me on that and never assume I know what offsets are....I mean, I know what they are, but not on every wheel, I just...nevermind.
mbusa.com
Old Aug 8, 2007 | 02:57 AM
sezer1986's Avatar
Lambo Murcielago `06, Bentley Continental FS Mulliner `06
mbusa.com
No Archaedus I think AMG is still constructing the GL63 AMG and I think it gets other 21" AMG Wheels you can see the pics here if you scroll down on the pricelist
http://www.mercedes-benz.de/content/..._GL_Klasse.pdf
Old Aug 8, 2007 | 01:07 PM
Archaedus's Avatar
Yep, those are the standard 21" wheels for the GL550 in the USA. Again, I have no idea if the GL and ML sport different offsets or if those would work, but it seems the R-Class's dont fit so it may be another option for you.
(I'd think that different tire sizes may be required though...?)
Old Oct 27, 2011 | 11:56 AM
03E55AMG's Avatar
Porsche Twin Turbo, Supra Turbo, EVO Turbo
I don't see any concrete answer on whether the GL 550 AMG style wheels could fit on a ML 550 ( Currently have the 19in AMG style wheels but would like to upgrade to the 21's) ....could someone point me to the right direction please?? All I've read is the "possibility" of the offset being different, however would it fit and look good ???
Old Oct 27, 2011 | 06:14 PM
VividRacing's Avatar
Former Vendor of MBWorld
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
Without having the car in front of me to measure, I can't say for sure but here's some ideas...
(This is assuming that the wheel specs posted above are correct)
On the FRONT:
AMG Style III, 21x9 ET60 will have 1mm less INNER clearance, and 27mm more OUTER clearance. A 25mm spacer and extended lug bolts would get the wheel almost back to stock track width.
On the REAR:
11mm more INNER clearance, 15mm more OUTER clearance.
The only issue I can see would be the brake calipers, but since you're going up an inch you'd probably be ok. In my opinion, you'll need some serious spacers to prevent it from looking "sunk in." H&R offers a ton of options, and we carry their whole line.
