ML 63 suspension ups and downs
I know that the car drops at speed, but is it normal for the car to adjusting like this fairly regularly. It feels real strange like the ground is moving.
p.s. I have adjusted my suspension countless times now moving the ride height sensors and its now in a 'happy place' - i.e balanced. No more big variances as there was when fresh from the factory, just composed and near roll free cornering.
you must have the air susp set in auto. therefore its going to continously adjust the suspension making sure you have a level ride given the pavement you are on.
if you select sport or even comf, you won't get as much movement in the suspension at the lights
Just file this under Stupid German Logic, there are times when the German's twisted logic drives me NUTS, but I still keep coming back for more.
Back to the suspension. Is the ML63 subject to the same up/down cycles when you lower the suspension per DoctorD? It sounds as though it still raises and lowers but the range is greatly reduced...
