Is 2000 ML55 and 2003 ML55 Hitch the same?
I am looking to add a towing hitch to my 2003 ML55. I have located a OEM hitch from a 2000 ML55, but I am not sure it will fit the 2003. Anybody know?
K
Also when removing your rear bumper be careful of the cellular antenna cable (if you have one). I almost ripped mine off.
In the meantime I received the hitch, and it looks as if the holes line up perfectly. Just need to get replacement bolts and washers now.
I also wish I had the OEM harness as well, oh well......
Since you then plugged in your OEM harness, where did you find the pigtail? I assume you did not have to remove spare tire etc. and access from inside the trunk, but rather through the vent after bumper was off??
you wanna sell your extra harness (or is it completely lost)?
A red light hitch plug with a blue dot looks good while you are not towing too. It plugs into the pigtail connector with a round nine to a flat four connect adapter. I mounted the pigtail plug underneath by the rear muffler and cut the painted piece with a dremel so it fits tightly around the square receiver. I can post some pics if you want.
A red light hitch plug with a blue dot looks good while you are not towing too. It plugs into the pigtail connector with a round nine to a flat four connect adapter. I mounted the pigtail plug underneath by the rear muffler and cut the painted piece with a dremel so it fits tightly around the square receiver. I can post some pics if you want.Regards,
Jerry
