ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Installed Lowering Links- PICS
Old Jul 19, 2013 | 01:38 PM
AMG893's Avatar
2010 C63 Estate
Hi All.
Finally got around to installing the lowering links into the ML.
The car had previously been lowered with Star Diag (as low as it could go without errors), but i just wasnt low enough. Especially the rear. The front was OK.
Anyway, so i installed the links, and it looks great now. Im very happy with it.
These are just some crappy iphone pics. I will post proper pics after i wash it etc.
Enjoy & comment!
Old Jul 19, 2013 | 04:47 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Totally changes the look. Does it handle ride different?
Old Jul 20, 2013 | 01:50 AM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
What are lowering links ? Can someone explain? And how come ou don't have any holes in your break rotors?
Old Jul 20, 2013 | 10:49 AM
AMG893's Avatar
2010 C63 Estate
The handling:
Hmm, i have to drive it around a little more to give an educated answer, but in short, its more "bouncier", in a tight way. Especailly in the rear, it can be felt. There is alot less travel in the suspension. Its not too bad. Will have to see how it goes.
Lowering Links are on vehicles that have air suspension. There is a Ride Height Sensor on all four Control Arms. Some only have three, two in the front one for the rear. It pivots. One side is connected to the Frame and the other a Control Arm. They move with the suspension and tell the computer what height the vehicle should be sitting at.
By changing the factory ones [factory ones are plastic, and fixed, they can not be adjusted], with after market ones, you can choose the length of the link that you desire, but winding it out, or in. These gives you full control over what height you would like the back & front of the vehicle to be. It still maintains the use of the Raise/ Sport/ Comfort buttons too.
I bought mine from http://www.airmatic-lowering-links.co.uk/. I bought them for my E63 from this site too. They are fast shipping, and good quality product. [i have no affiliation with this site]
As far as drilled brakes, my only explanation, is that my car is Oct 2008 Built, Feb 2009 complied. I guess, the very first of the facelift, still had the pre updated discs, like the early 2008 / 2007 model ML63's.
My discs are due for replacement soon, and i will be getting drilled ones.
Old Aug 3, 2013 | 09:57 PM
EVOII_Racer's Avatar
Mercedes Evo II
Wow damn so sick me like a lot
Old Aug 4, 2013 | 12:40 AM
Rippin'AV's Avatar
2008 ML63 AMG
I really need to get me a set of these! Great looking ML!
Old Aug 4, 2013 | 01:56 AM
tc1728's Avatar
That looks great, I like it a lot. TC
Old Aug 5, 2013 | 08:52 PM
AMG893's Avatar
2010 C63 Estate
Thank you!
Old Jan 29, 2014 | 06:43 PM
schmick325's Avatar
RR Evoque Dynamic, Benz Valente (work hack)
The rotors are not drilled, only dimpled. When they are worn, the dimples are no more and you are left with a normal looking rotor
Old Jan 30, 2014 | 10:35 PM
MercedesDad's Avatar
New, old Mercedes and REAL AMG's.
Does anyone know if doing this would represent additional stress/wear to factory air ride elements? I would love to I stall these!
Old Jan 31, 2014 | 12:19 AM
Rippin'AV's Avatar
2008 ML63 AMG
I've also questioned this???
But also, is there anybody doing coilovers or lowering sport springs for the ML? It cant be that hard to do. You would have to trick the ECU/Airmatic systems because of the lack of airbags but its been done for years on Land Rover conversions. Cant be that much of a difference. I would much rather have a solid coilover setup where I can adjust damping and such for my driving style.
Any vendors up for the challenge?!
Old Feb 1, 2014 | 11:03 PM
AMG893's Avatar
2010 C63 Estate
I think lowering any car is extra stress on items like rims & tyres, etc, as there is less absorption from the suspension, thus moving the energy to rims/ tyres other components, when put to the limit.
I didnt go crazy with my lowering, so i dont think its too bad.
Absolutely, coilovers/ removing AirMatic and replacing with a traditional spring/ shock setup is ALWAYS best, when it comes to ride quality. It will remove that "bounce" associated with the airmatic when lowered.
But for an inexpensive way to lower the car, and as a start, i think Lowering Links are a good alternative. $150 for lowering, and it can still be adjusted from the factory setup is great.
Old Jun 3, 2015 | 06:38 AM
daniel8699's Avatar
ML63
Hi there!
Did you use the fixed or adjustable links?
Old Jun 3, 2015 | 07:42 AM
AMG893's Avatar
2010 C63 Estate
Adjustable
www.lowermyairride.co.uk is where i bought them from
Old Jun 3, 2015 | 08:27 AM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
More info of mine..
https://mbworld.org/forums/new-m-cla...mmed-pics.html
Old Jan 6, 2017 | 12:58 PM
markmassive's Avatar
2011 ml63
The handling:
i also installed lowering links but now my rear suspension is not working. I got a malfuction error but when i turn the car off and turn it back on the error is gone. also When i i press the airmatic button to raise or lower it doesnt stop raising or lowering on the command cluster, but it doesnt even lower or raised.
Old Jan 6, 2017 | 01:42 PM
Nanook's Avatar
Sounds like you may be over passing the limits ..
Old Jan 6, 2017 | 01:51 PM
Pee Don Yu's Avatar
2011 ml63
I probably did because the rear's are lower. What do I do now to fix it.
Old Jan 6, 2017 | 02:22 PM
Nanook's Avatar
Revise the length of the links..shorten I think
Old Jan 6, 2017 | 02:28 PM
Pee Don Yu's Avatar
2011 ml63
I put The link to the same measurement as the stocks and it still not raising or lowering. FYI the ride is sooooooooo bumpy on the rear and the fronts are perfect.
Old Jan 6, 2017 | 02:30 PM
Nanook's Avatar
You may have twisted the sensor lever 360 or 180 degrees to far..dunno without seeing it..take to dealer and ask them to reinstall stock links
Old Jan 6, 2017 | 02:34 PM
Pee Don Yu's Avatar
2011 ml63
I thought that to and I can't seem to find how it should look like online.
