ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
W163 Coolant System question
Old Feb 23, 2014 | 11:57 AM
Rotorhead's Avatar
2001 BMW 740i, 2000 MB ML430
The wife has a 99' ML-430 that I just finished replacing the cracked coolant tank on. I've filled the tank to the line but won't I have to purge the air out of the system? My BMW has 2 Bleed Valves on the block for burping it, what procedure do I follow on the ML-430? Are there bleed valves and if so, where are they located?
Old Feb 23, 2014 | 06:05 PM
vvrjrlaw's Avatar
1994 S420 RIP (2/8/13), 06 CLS55, 02 ML55, 94 TT Supra, 89 Maserati 228, 911 Porsche Carerra
It would seem that if you were watching the expansion tank to keep the coolant level up changing it would not necessarily require a full bleed of the system just run the car with the cap open and top it. When I change coolant I remove the thermostat housing hose and prop open the thermostat while I fill the radiator. Once coolant reaches the top of the housing I put the hose back on, let the car run to operating temperature with the cap open and top off the radiator. I then close the cap and shut it down, let it cool and check the level. If it needs any further topping off I do it and close it up. It's time consuming but gets it done.
