ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Wider Tires
Old Oct 1, 2016 | 09:46 AM
Royce63's Avatar
'12 Camaro '09 C300 '14 Jeep SRT '13 650i Gran Coupe '13 ML63 AMG
Wider Tires
I'm currently running 265/45/20 on my ML63 AMG. I'm interested in running 295/45/20, will that cause any infractions or rubbing?
Have anyone else changed the tire size on their ML63? If so, how much wider did you go?
Old Oct 1, 2016 | 09:05 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
A 295/45/20 is a much taller tire than a 265/45/20. You would probably want to run a 295/40/20, so the height of the tire isn't changed.
Old Oct 2, 2016 | 09:58 AM
Royce63's Avatar
Thank you, that wouldn't case any damage?
Old Oct 4, 2016 | 10:12 PM
AKnight55's Avatar
No you would be fine.
Old Oct 22, 2016 | 11:15 PM
Royce63's Avatar
Thank you, I'm thinking about the changing the entire wheel set. So I haven't changed the tires yet.
Are you in Brooklyn?
Old Oct 23, 2016 | 09:12 AM
AKnight55's Avatar
No I'm in New Hampshire
Old Oct 23, 2016 | 11:15 AM
Royce63's Avatar
Oh ok, thank you.
Old Jan 18, 2017 | 06:36 PM
FutureAMGxx's Avatar
C55 AMG
Recommended/stock tire size is 295/40/20 so you definately shouldn't have a problem.
Old Jan 19, 2017 | 03:21 AM
Royce63's Avatar
Thank you.
Royce63's Avatar
On the 2013 ML63???
Old Jan 19, 2017 | 11:29 AM
C55 AMG
Originally Posted by Royce63
On the 2013 ML63???
Oh hmm, figured it was a w164. Oe for a 13 is 265/45/20 or 295/35/21
Overall diameter is 29.40" for a 265/45/20. Overall diameter is 29.30" for a 295/40/20 so it will definitely work height wise! Shouldn't even notice a difference!
