2007 ML63 engine issues
Thoughts?
Car stalled, got it towed to mechanic. Something broke in engine and punctured oil pan causing engine to seize. Mechanic says I need new engine. Have researched online and found that this engine has had problems in the past. There was a class action lawsuit started in the US.Has anyone had any success in getting MB to pay for repairs?
The lawsuit failed/was dropped. The car is 10 years old, I don't think they'll pay for anything. The engine has three weak points:
1- Camshaft adjusters.
2- Camshafts eating thru the valve lifters/tappets. Seen few cases where the valve drops into the cylinder.
3- Headbolts breaking, causes coolant to leak into combustion chamber and breaking rods and contaminating bearings.
Do you know the engine serial number? If not you could give me your VIN.
Good luck.
I am in West Vancouver, BC.
The mechanic just said the engine seized and recommended a new engine. He has not proceeded to take it apart and determine what the failure was.
He is sourcing out a used engine but not sure if it will be worth the cost. Its a shame because I do love the feel of the car.
MY VIN is 4JGBB77E98A347566
I'll reply there.
Cheers.
Received a check engine warning message saying to check coolant level, engine loss power and ran rough. I was less than a mile from home so I drove it there. At home I added 1/2 gallon coolant and 2 gallon water to proper reservoir level. Started car to see if warning light was off. Engine immediately seized. I took the car to my Mercedes dealer and they said the engine seized and needs to be replaced. What could have caused this? Would I be risking the same problem with a used engine from a salvage company if I found an engine? Anyone have similar problems like this?
For now, you can check the engine for piston/rod damage if everything checks out, it is a matter of replacing head bolts with the new design, new gaskets, fresh oil and coolant. If you buy a used engine, make sure the serial number is after Engine # 60060658, otherwise, buy an engine and replace the head bolts while it is outside the car.
Good luck.
Good luck.
bought my self w164 and love it...
just want check engine series to check if can avoid and trouble
thanks!
Good luck.
- looking to buy VIN
- 4JGBB77E17A271307
- any info on work or problems?
Thoughts?
But I have 2 good news. 1. The prices of 63 amg engine parts are several times lower than the parts for ML 55 / w163 /. 1xPiston for ML 55 is the same price as 5x piston for 63 AMG. 2. good news - a seized engine is never seized all / everywhere
What happens to that seized engine when the Parts Changer replaces it? I would like to send all the bad engines
Previously, the timing chain in the engine did not even have to be changed. Today, the timing chain must change. And the 272 engine has to get out of the car.
Engine 272 from w164 350
