ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
2008 ML63 AMG Cylinder 5 Misfire
Old Mar 22, 2018 | 01:25 AM
Wasoup's Avatar
2008 Mercedes ML63
Hey guys, have a 2008 ML63 amg. Recently its been misfiring on just cylinder 5. Have replaced all the plugs, cylinder 5 coil and injector, but still misfiring.
Once in a while the car runs perfectly with no misfire or other issues.
Also noticed that when a full tank is put in the misfire disappears for a few minutes.
As well when we replaced cylinder 5 injector it ran perfect for about 5 minutes before starting to misfire again.
The codes coming up are P0205, P0305, P0050, P0330.
Anybody have any similar issues?
Old Mar 23, 2018 | 12:22 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
P0050: HO2S Heater Control Circuit B2S1
P0330: P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
What is the mileage? at that age, the O2 sensors might need replacing.
Also, consider replacing maintenance items, like intake manifold gasket and PCV.
Good luck.
Old Mar 23, 2018 | 12:42 PM
ItalianJoe1's Avatar
2003 CL 600
Intake manifold gasket leaks are common on the higher mileage early 156s. Especially since it's a front cylinder, I'd check that next.
Old Mar 23, 2018 | 01:51 PM
Wasoup's Avatar
2008 Mercedes ML63
Thanks for the replies. The cars got 185kms. I will definitely check the intake manifold gasket next.
Whats got everyone stumped is how the misfire disappears for a few minutes when the car is filled up.
