ML63 AMG (W166) 2011 -2015 (Replaced by GLE63)
New 2013 ml63 owner mixed emotions
Old Feb 4, 2018 | 01:30 PM
BillClap's Avatar
Ml63 2013
On the upside, super happy about my first amg vehicle, the ml 63 is a beast.
Think I got a good deal, bought a 2013 ml 63 amg in December 2017 as certified pre owned from mb dealer with 80000km. Previous owner had got the extended warranty so still have 2 years of warranty, 1year almost full and last year motor and transmission, ohh and I didn’t need to pay for it.
On the down side, I already had to use the warranty.
1st problem- Car would not shift into gear, and the turn signal would not always work, they changed some control parts, all is good now for the shifting.
2nd problem- Car seemed unstable, they changed some sensors and some tie rods.
3rd problem- didn’t go to the dealer yet, but would like to get the opinion of others before I go.
There seems to be some, mild jerking feeling when the car down shift from 3rd to 2nd gear.
4th problem- don’t know if it’s actually a problem, but I find that on a cold start it revs loud for about 20 secs, before calming down to a normal rev.
Also, all this makes me think that certified pre owned, means nothing, I have had the car flow about 1month with almost equal time in the shop.
not to mention my customer service from the salesman was horrible.
Any thoughts or advice?
Thanks! Also will try to post some pics of the car as soon as I can get it clean, not an easy task with winter.
Old Feb 5, 2018 | 05:45 PM
NickTheStick's Avatar
W213 E63s
First, congrats. Its an amazingly well-engineered vehicle, and full throttle will bring a smile to anyone's face.
Harsh 3 --> 2 downshifts seem somewhat common. When I was looking to purcahse, quite a few I drove had a similar issue. Question, is it only harsh in comfort mode? Mine is a bit harsh in comfort but smooth in sport mode. A dealer told me its normal...
I assume since the vehicle has a new trans, you don't yet need a service. Do you know how many miles on the trans?
Cold starts usually result in raised idle for 20ish seconds, completely normal.
Old Feb 11, 2018 | 09:58 AM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
3rd and 4th issue are normal. The 7 speed isn’t the smoothest but used to handle the extra power and torque.
Old Feb 12, 2018 | 12:49 PM
scottiekay's Avatar
2019 GLC63 and 2018 Jeep Trackhawk
So I just bought a 2014, the on the cold start does rev and what you are experiencing is normal. I actually wish that it was that loud always. They sell a downpipe with high flow cats that will increase the rev volume dramatically. the mild jerking could be caused by your lane keeping assist. I had to shut it off because it was annoying.
Old Feb 12, 2018 | 12:53 PM
Chedman13's Avatar
I have a supersprint midpipe that removes the resonators and that improves the sound a lot with no drone.
I also have a Brabus exhaust that improves the sound even further - I recommend both!
Old Feb 12, 2018 | 02:56 PM
scottiekay's Avatar
quick question where did you get the super sprint mid pipe from, looks like there website is not in us dollars? also, the resonator delete is something I want to do. If I just do that only how much better is the sound and would there be drone with the stock exhaust?
Old Feb 12, 2018 | 03:12 PM
Chedman13's Avatar
You have to call and special order from https://www.ecstuning.com/ they are the official supplier in the USA. It took me a few weeks to get from Italy.
No drone. How much better is subjective, but for me, it's 2x better than with resonator. The cheaper option is just cut out the resonator and replace with straight pipes, but I didn't want to do any cutting. Any exhaust shop can do that in 1-2 hours. Just be sure they use stainless steel tubing.
Old Feb 15, 2018 | 09:39 PM
Kayos77's Avatar
2012 ML63 with P30 package
your 3rd and 4th concerns are normal. i had my ML63 for a little over a week before it spent 5 weeks at the dealer getting new cam sensors, engine wiring harness, O2 sensors and a passenger side turbo.....all covered under my extended warranty!!!
Old Feb 16, 2018 | 08:30 AM
BillClap's Avatar
Ml63 2013
Thanks for the reply!
The trans is still the original, it now has 84000km
I finally, brought it to the dealer to see what they could do about it, they updated the software for the transmission, it help for a 2 days, then it started to do it again.
Old Feb 16, 2018 | 08:32 AM
BillClap's Avatar
Ml63 2013
What where they symptoms you had to get all that changed, and did it help?
Old Feb 16, 2018 | 08:35 AM
BillClap's Avatar
Ml63 2013
Nice, if you don’t mind me asking, what is the rough total price for the mods?
And do you think you can send a sound link?
Old Feb 17, 2018 | 07:42 PM
Kayos77's Avatar
my check engine light came on. code was for an O2 sensor. when they looked into it more, it was oil migration through the cam sensors and harness and it shorted out the ECU. they had to drop the motor to get part of the harness out and thats when they noticed the turbo fan blades were damaged. after all was said and done, extended warranty paid just under $11,000 for repairs!!
