ML63 Low Oil Light
ML63 Low Oil Light
Does the W166 ML63 have a low oil alert that is displayed on the dash? Asking because I had oil changed about 6 months ago but have not put on many miles. I went to check the oil and it seems to be at “MIN” level. Unless I am totally reading the dipstick wrong.
Edit: I’ve checked the manual and I know it says it does, but I just want to make sure there isn’t anything that could be wrong with my notification system.
Thanks! It’s just very odd because checking today, I waited for the engine to reach operating temp and then pulled the dipstick out. Wiped off and reinserted and i can barely see the oil line. I wiped off with microfiber and there really was no residue above the MIN marking making me think I am dangerously low. It is 20 degrees here in Michigan
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/1500x2000/94e6cfa1_dc8f_49d7_b919_7e1d93d69c1f_9d34ba63fc2393733f8329c2fd426ccf0ce10759.jpeg)
Not sure if it’s because I’m getting old or the style of this dipstick but it looks like the oil is at a good level. I really don’t want to add a quart unless I get a message or I can tell for sure. I might need to just get a new dipstick.
I am hoping that’s not the case. Checking the oil again I can see there is a film of oil up to the middle of the “min” and “Max” locations. It’s just difficult for me to see and not as obvious as the traditional types of dipsticks.
Too many to list
I actually had the engine get to operating temp, turned it off, waited 5 minutes and then tested. It’s per the manual.
