FOR SALE: Custom W203 Bi-Xenon Quad Projector Headlights
I changed almost every plastic part inside them with the oem stuff including the adjustments screws and all that other stuff.
The Bi-Xenon projectors are the OEM E55 projectors that come standard on Land Rovers, E55s, Benzes, BMWs etc. The reason I chose these is because they fit almost like stock in the mounting holes and dont require the headlights to get all cut up.
The bi-xenon's are wired up to work just like oem and the oem high beam is still there so when you turn on the high beams you have two in each light, this does not consume any more power than normal as the bi-exenons highbeam works by a lid that is fliped.
The area where the oem highbeam and city bulb is was converted to a projector and uses the same shourd and projector so they match.
All the wiring inside the headlight was soldered, heat wrapped and electric taped.
The hid kit is a 55watt DDM tuning 6000k D2S bulb kit with a lifetime warranty.
The ballast is mounted under the headlight with custom made brackets that screw in from the bottom and make replacing a breeze should it ever need it.
The dust covers have been modified to fit the hid cables.
Honestly this is a better, brighter,cheaper and better looking setup than oem b-xenons with the same quality. And oem doesnt give you a lifetime warranty on the bulbs and ballast and makes you open the headlight if you have to replace it.
These lights are plug and play everything is done for you.
Btw I want 600 Shipped for this setup.
Here is some pics of how everything is mounted and how they look.
Some videos of them starting up and cutoff and video of bi-xenon in action.
ive depos with hid on my gfs c230k sedan... cut off is CRAP because the projectors are so bad..
thank you so much.
When I plugged them in it showed no error on dash and no flickering or any faults and my car is no programmed for them but they work like stock since its stock 55wattage instead of the usual 35w with other hids including oem bi-xenon.
I could ship to canada but how does customs and duty stuff work?
