DYI S65 shiftpads
part no for the pads are: A 171 267 00 46
they are REAL metal and quite heavy
i got a friend who works @ mb so i payed just under 200$ incl tax for them but they arent that expensive..
first remove your steering wheel.
there is 2 torx 25 holding the airbag in place
after that the steering it put in place with a big umbraco size 10
the new pads are more square than the old so you need to make the hole bigger, i used a dremel for this job...
once that was done, i used 2 screws i just had lying around to hold the pads in place since the old was way to small..
on the DOWN shiftpad, there is 2 wires, a blue and a black.. the black one is placed correctly, the blue have to be moved to center position
now reverse the process and you are done
The part number is for a set left and right
And yes its a original steering wheel with the small black shifters in the back
