Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
300E turbo project (Update new setup)
Old Aug 9, 2007 | 07:51 PM
  #76
jassem99's Avatar
Roman, did I miss something along the way or are you saying you were running high boost and 9000rpm in an M103 with only CP pistons and O-rings?! No upgraded cams/valvetrain to support the revs? Simply incredible. How come the M103 can survive the high revs? Does this mean the M103 is better suited than the 24v M104 for big power?
Impressive work Roman. Very impressive.
Old Aug 9, 2007 | 08:40 PM
  #77
PUMPISH's Avatar
Thanks!!!!
No CP pistons and no O-rings, this is my other engine.
This time I was running completly stock engine with stock pistons, rods and no o-rings. Stock cam, valvtrain and everything just stock. yes I think that m103 one of the strongest engines ever buid. M104 head is weaker then M103.
I just love M103!
Old Aug 11, 2007 | 04:03 PM
  #78
jassem99's Avatar
Standard internals?! That is even more impressive. Does the M103 head use solid lifters? With the BMW M20 problems start occuring with the rocker arms at over 7000rpm.
Roman, may I ask what turbine housing you were using? 19cm^2 perhaps? And do you have the standard 65mm turbine wheel or the bigger 70+mm one?
Old Aug 11, 2007 | 05:04 PM
  #79
PUMPISH's Avatar
Yes all parts of M103 head is more solid then M20 head
I allways use rev limit at 8000rpm even with my winter car 190 2,6 I have rev limit at 8000rpm and I never had a problem for 2 years now less I instal MS II
Turbocharger I use is GT45 is good for 900-1000Hp
Compressor house:
A/R 0,66
Compressor wheel inducer 70mm
Turbin house:
A/R 1,05
Turbinwheel inducer 80mm
Old Aug 21, 2007 | 12:26 PM
  #80
mercedesturbo's Avatar
Hi
beautiful project.
I have a turbo c280 with C36 camshafts. (MoTec ecu)
What do you think is the Max rpm I can go with the hydraulic lifters
Old Aug 29, 2007 | 07:14 AM
  #81
PUMPISH's Avatar
Originally Posted by mercedesturbo
Hi
beautiful project.
I have a friend making 9000 with 2,3 16v so I thing that 8000 would not be a problem but you should be carefull about your rods
Old Aug 29, 2007 | 07:15 AM
  #82
PUMPISH's Avatar
the tranny steelcross looks very sexy
Old Aug 29, 2007 | 01:12 PM
  #83
Thanks for your answer.
I do have 4340 custom made rods. However if I am not mistaken the 2.3 enginf is M102 with rocker arms, and my engine is an M104 engine with direct hydraulic valve lifters so the geometry is very different and the valves may float at a different RPM.
Old Aug 29, 2007 | 09:08 PM
  #84
PUMPISH's Avatar
2,3-16v hydraulic like yours
Old Aug 30, 2007 | 01:56 AM
  #85
My mistake. That is the Cosworth designed head.
Does your friend car is with Turbo?
I would like some opinion if to keep the cams timing original .
My engine power drop at high RPM (Back pressure I guess).
My max rpm so far is 7000.
Old Aug 31, 2007 | 11:46 AM
  #86
Sunny55's Avatar
2005 SL55 AMG
Wow...good work man! Very impressive build....nice motor...
Good luck with yoru future projects
Old Aug 31, 2007 | 12:24 PM
  #87
Now I v finaly killed the engine
For 1 week agow when I was driving at the highway at 2bar one of the radiator water pipes came loose and I lost all water the same time I was racing with some motorcycle on the highway. I did not want to lose and I was driving withot water in the enine for while and headgasket broke.
I had no engergi or money to fix it right away so I was driving the car for 1 week with broken gasket and I got more and more water in the oil inside the engine every day but I keeped on driving at 2bar and 9000rpm the whole week before the engine began sounds strange. I have many other plans with my car and thats why I have no energi, time or money to fix the engine now so I going to fix it for the next season. So now I will have time to finish my album with my band
http://www.youtube.com/watch?v=Tl2xMFNefXU
Dear Pumpish,
You did not tell us the end of the story.
Who won the race you or the motorcycle?
What kind of motorcycle was it?
Please
Old Aug 31, 2007 | 02:45 PM
  #88
PUMPISH's Avatar
Dear Pumpish,
Please
Nice car man!
Yes my friend has turbo and around 450hp
Yes of caurse I won the race but it was pretty stupid to keep driving at 2bar boost without water in the engine and 140 degree
It was the secound time I won race with 1000cc sport motorcycle.
We start race at 50km/h up to 200km/h
It was black suzuki 1000cc and first time 1000cc kawasaki
Old Aug 31, 2007 | 03:46 PM
  #89
It is unbelivable. I mean to keep up with 1000cc motorcycle .
The most difficult part is the start at 50 KMH. How do you keep from loosing tracktion? What kind of tires (Rear) do you have ? Do you build boost before you start?
Old Sep 22, 2007 | 09:25 AM
  #90
PUMPISH's Avatar
I have michelin pilot sport 255/35/19 and with GT45 turbocharger I have so soft curv and much better tracktion. On streetrace I use launch control sometimes and build boost before the start
Old Sep 22, 2007 | 09:27 AM
  #91
PUMPISH's Avatar
I found some old fimls when I was runing at 1,3 bar untuned on very smal 70km/h road before I increased to 1,5 and then 2bar.
http://www.youtube.com/watch?v=UVazDWI2ouk
http://www.youtube.com/watch?v=3wl7ZG3_gwM
Old Dec 19, 2007 | 03:34 PM
  #92
SaMaS's Avatar
02 996 Turbo, 05 CLK55 AMG
WOW very nice job !!! makes me want to get 300E... good luck with your porject in future keep as posted !
Old Feb 13, 2008 | 10:17 PM
  #93
Dan_Audio Man's Avatar
'87 300E
Roman - outstanding work...keep the youtube vids coming!
And when you going to turn my '87 into a turbo ?
Old Feb 16, 2008 | 07:55 PM
  #94
PUMPISH's Avatar
Thanks!
Just bring it here!
Old Feb 17, 2008 | 02:04 AM
  #95
'87 300E
Thanks!
Just bring it here!
How do I know if my '87 has the m103 engine? I have the US spec automatic version.
I have pics of it here :
post 1762
https://mbworld.org/forums/showthrea...=37773&page=36
Old Jun 4, 2009 | 09:37 PM
  #96
ABUBBY's Avatar
E500
Hi
can you put Photo Again
