KLEEMANN SC systems over priced? Look here.......
Lets look at facts.
There are three systems on the market.
ESS, HPS and KLEEMANN. All use different superchargers (SC) to make power. The difference lies in SC efficiencies.
SC/Turbo efficiency: SC/Turbo efficiency is essentially the ratio of useful work produced by the SC/Turbo from the work required to drive the SC/turbo. An increase in temperature is of course a by product of compressing air and is unavoidable. A higher SC/turbo compressor efficiency value means lower charge air temperature. Naturally, lower charge air temperatures assists in improved engine durability with the potential to achieve even higher power and torque output. The efficiency is measured in percentages. Where 100% is an ideal number. The closer you are to this number the less heat SC/Turbo generates.
Lets look at each indiviual system:
ESS:
They use Vortech, centrifugal SC, no intercooler, no EPA/CARB certification.
It is basically half of a turbo mechanically attached to the crankshaft. The unit is fairly efficient around 70%. Personally, I have a lot of experience with it, as it is used extensively in FORD and CHEVY late-model aftermarket. The problem with a VORTECH, is that it builds boost with RPMs. So maximum boost is not reached until redline, leaving midrange and lowend - soft. Most customers who install VORTECH systems end up trying to make up for soft bottom end by increasing SC pulley ratio. Eventually end up with damaged engine as there is now too much boost on the top end, leaning car out.
HPS:
They use EATON M90 roots SC, no intercooler, EPA/CARB certified. This SC is not really a compressor, it a positive displacement SC. It simply grabs air with it's lobes and compresses it inside the intake manifold. Because of this, it's efficeincy is fairly low, in 50-60% range. In my personal experience, EATON, at low boost levels 4-6 psi can make decent power. Anything above will increase air charge temperature dramatically, resulting in detonation. Lack of intercooling is a big concern, since 91 octane gas that we currrently "enjoying" in CA is coming to all states within next several years. Also on bigger engines like 500 and 55 M90 is too small. It is only 1.5L in displacement, so to make equal to smaller engine's (430) boost it has to be turned faster, thus creating more engine damaging heat.
KLEEMANN:
They use Lysholm screw compressor, intercooled, EPA/CARB certified.
Compressor is sized to engine displacement from 1L for V6 models to 2.2L for 55 models. Lysholm has efficencies in the range of 70-80%. KLEEMANN also uses LAMINOVA intercooler cores that are very efficient (80-90%). What it means is that on their kits, air charge temperature is only around 20-30F higher than ambient at full boost. One of the first kits we installed was in the summer with outside hitting high90s, yet charge temperature never rose above 120F. Knock sensors were happy and DME was giving the car full timing advance. CLK55K made 420HP/420TQ at the wheels and ran like a proverbial "bat out if hell", with perfect driveability and throttle response.
If you add proven track record in Europe, very well engineered and integrated compressor/intercooler/water pump assembly and factory appearance, it is easy to see why we sell only KLEEMANN.
Ted
..........yes it is. But add up the cost of Kleemann s/c plus instal $15K, headers plus install $5k, ECU $1.8K, boost kit for the Kleemann s/c $1.5K, Kleemann exhaust $2.5K, Kleeemann camshafts plus instal $3K. This adds up to $32K. Rentech high boos s/c is $37K. The truth is that there is really no price difference. The Renntech low boost s/c delivers about the same HP as an unmodified Kleemann s/c alone and both cost about $15K.
Ted
Ted
Ted
Ted
Ted
Which if freaking insane. It's a shame, as I believe the factory exhaust manifolds are pretty restrictive and I think that the CLK55 would benefit as well as any car can from a properly designed set of headers. I think that the rest of the exhaust, sans catalytic converters, are pretty free fowing, and all I really want are headers, but the Kleeman headers require their own downpipe which eliminates the primary cats, and at that point I might as well get the whole system.
Renntech sell headers for the C55, but curiously not for the CLK55, although I was under the impression that the C55 essentially has the front end of the CLK55. It ultimately doesn't matter as they want $4995 for their headers!! What's with these insane exhaust prices?!? I imagine installation's pretty expensive as well. I wish someone would step in with some reasonablly priced aftermarket options. I refuse to pay these outrageous prices...
Best regards,
Matt
You must understand the reason why they charge so much however.
The first point is that the research and development that goes into making these products. Certainly someone with a 50,000$ car doesn't want a product that cannot stand the real world!
Second, these aren't mass produced. The reason headers for a Civic are a few hundred dollars is becaue the company can recoup their losses from a larger audience. How many guys with C55's and CLK55's will buy these headers? Certainly a lot less.
Third, folks are used to it.
I remember reading somewhere that the cost in 2003 to manufactuer a SL500 was around 16,000$.MSRP on that car I think is about 89,000$.
:p How time flies..
