E55 Kleemann
2002 E55K RENNtech HP
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
What are full Kleemann specs and how does it run? I see lots of "full Kleemann specs" and have yet to understand what this means.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Former Vendor of MBWorld
Supercharger
Suspension
Brakes
Spoilers
Exhaust System
Interior
Steering Wheel
2011 GL450
Originally posted by KLEEMANN
On the dyno:
RWHP: 423
RWTQ: 430
On the dyno:
RWHP: 423
RWTQ: 430
I guess I might be able to take it in weight savings?
Tim
.... how does it run? ......
Originally posted by Timster
It's got more HP & Torque than the CLK55! Grrrrrrrrrrrrr....
Tim
Tim
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
NOT COMPLETE - SOMETHINGS MISSING?
Cory, where are those awful 'Pepto-Bismal' colored engine covers and brake calipers?![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
![](http://www.kleemann.dk/images/clk208/clk55k-engine300.jpg)
![](http://www.kleemann.dk/images/small/brakes-r-320mm.jpg)
I like the look of this V6 cover (plus it has dual intakes):
![](http://www.kleemann.dk/images/c203/c32k-engine-250.jpg)
What happened to the E55's dual intakes/filters that I have seen on other AMG 5.5 installs? Your E55 install looks like an E430.
I don't know if I am reading the chart right. but what accounts for the reduced s/c output (red line) compared to the original numbers (green line) for the speeds below 70.
Flooring a 500+HP CLK on the dyno would screw up the chart (not to mention make a lot of smoke in an enclosed building). The tires would break traction through 80mph.
2011 GL450
Originally posted by Mach430
Flooring a 550HP CLK on the dyno would screw up the chart (not to mention make a lot of smoke in an enclosed building). The tires would break traction through 80mph.
Ben let off the gas man! cough, cough!
Just teasing you,
Tim
2011 GL450
Mine only gets a little cloud of smoke
When you come down for your check up, make sure you bring an extra set of tires! That way, we can go have some fun
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
And those headlights all on at the same time you must have busy.
I hope those were extra tires!
Tim
