AMG C43 Water Pump Fan - Redundant?
What are some opinions on this and has anyone remove it?
Vadim, Ben?
Thanks,
Jeff
2003 C230K magma C5, C7, 6 spd.
Unless you live in a very hot climate - 95F plus most of the time and drive in constant traffic.
Thanks for the info. I am going to machine a set of phenolic heat spacers to go between my intake manifold and cylinder and when I get that going I will get those pulleys.
Thanks,
Jeff
I experienced my self at a racing event where we lent out a CLK 55 K to race driver Jason Watt, that the car drove on a very short low speed track with only overheating 1 time over a whole weekend with endless drives and over 30 2-300 meter burnouts and donuts, 1 lap at normal speed took care of that.
On dyno a S/C E 280 V6 have 265 HP with the fan and 285 without. Just make sure the electrical fans are working corect before you remove it ( remember it a links, when dismounting )
One the car runs at the same temp without the fan as it did with the fan. So no change there.
Two the radiator hose that runs from the thermostat housing to the drivers side of the radiator began to rub on one of the pulleys to the piont of developing a leak.
So if your remove the fan make sure the radiator hose is secured so it can't rub one of the pulleys.
Jeff
Looking at the hose location with the car static you would not think that it could be forced back into the pulley by airflow through the radiator.
Jeff
Yea, your going to want to keep that fan there. The two fans in front only come on when the car is not moving and warmed up or if the A/C is on and it needs to bring down condencer temp. I agree that the new models with one big electric fan behind the radiator is a better idea but they just diddnt think so back then or something.
I have no experience with the 560, but it's working the same way, there is only one way to find out, and that is to dismount and see if the electrical fans can take it or not, I think it won't be a problem - the gain is aprox. 15 HP.
The 560 had no such provision. Do not remove it from this car.
On the others, I have had no problem with removing the fan...(yet).
We have removed 12 or so in the last year and a half.
however I haven't really felt any difference either.
