Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
took off my muffler....
Old Jul 12, 2003 | 04:00 AM
CL600_W140's Avatar
I took off my muffler and put stright pipes back ... sound great on my V12 .. got that exotic car sound going.. will this harm my car?
anyone know?
Old Jul 12, 2003 | 01:00 PM
Lynn's Avatar
No, it won't harm the car, just **** off the neighbors.
Old Jul 13, 2003 | 11:51 PM
///AMG124's Avatar
1994 MB E420 RENNtech
Backpressure?
Old Jul 14, 2003 | 11:44 AM
Lynn's Avatar
Lower back pressure will cause a reduction in low and mid range torque, but won't hurt the engine.
Old Jul 14, 2003 | 01:17 PM
Steve Clark's Avatar
C32AMG
I agree with Lynn
The neighbors will start to think of you as an annoyance and an idiot...or do they already know it?....That's where the harm will come from. ...
Old Jul 14, 2003 | 04:03 PM
CL600_W140's Avatar
I thought...
It should increase preformance.. does anyone agree?
Old Jul 14, 2003 | 04:27 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
You are telling me that your CL600 V12 is not fast enough for you???? It's built for comfort and a great grand touring vehicle with a lot of power already.
Old Jul 14, 2003 | 04:36 PM
CL600_W140's Avatar
I need more...
I seen a car like mine with over 700 hp... I want mine to be atleast 500-600 hp....
Old Jul 14, 2003 | 04:58 PM
dtkw's Avatar
LOL, you probably saw a Renntech or something along that line. Really, then you should consider having Kleenman or Renntech to modify your car to get that kind of hp. You'd probably gain 2 seconds or less to reach 60 if that's important to you. Right now you get some unhappy neighbors and hairline gain in performance. Good luck and enjoy your ride. I am sure it's very nice already.
Old Jul 14, 2003 | 05:04 PM
izzodesh's Avatar
ML 55 and 420 SEL
yeah renn tech it cuz its a cl600 dont go cheap..
u will regret it hardcore
Old Jul 15, 2003 | 02:14 AM
JBrady's Avatar
Removing the muffler may or may not hurt velocity within the exhaust system. It is velocity NOT backpressure that is wanted. Backpressure does NOT increase low/mid RPM power/torque. This is a wives tale due to the fact that increasing exhaust pipe diameter and/or other seemingly good ways to decrease pressure actually hurt low/mid RPM performance. The culprit is a loss of velocity. Ideally, you would maintain low/mid RPM exhaust velocity, and thus maintain scavenging while not creating any high RPM backpressure.
So, you may or may not have gained any usable power but you definitely lost some weight :p
Old Jul 15, 2003 | 02:23 AM
CL600_W140's Avatar
Sounds good tho!
really loud in a good way.. but, if I am losing proformance.. then forget it.. I will put back the orginal muff.
Old Jul 15, 2003 | 01:13 PM
speedybenz's Avatar
AMG C43, 1999
CL600,
You probably gained some Hp, but all the way back at the muffler does not change the velocity of the exhaust flow much unless your stock muffler had really high amounts of backpressure.
I would guess that the Cat Convertors near the motor are the controlling factor to backpressure, besides a poorly designed header/manifold.
And JBrady is right the backpressure comments about losing low and midrange Hp are wifes tales.
Jeff
Old Jul 15, 2003 | 02:00 PM
Lynn's Avatar
Originally posted by CL600_W140
Sounds good tho!
Put the car on a dyno and do runs with and without the muffler. Then you'll know for sure. Any changes are probably pretty small. MB does a good job with their exhaust systems.
Old Jul 23, 2003 | 10:51 PM
FIXEDupW209's Avatar
A bucket on wheels
why dont you just buy a porsche? a cl600 is a pretty heavy car it would be ridiculous to spend so much money on renntech mods when you can just invest that much in a lighter, cheaper car. Also why didn't you buy the cl55 amg if you wanted a sportier car? although they do register as having pretty much the same 0-60 times...the amg is deff sportier and lighter.
Old Jul 24, 2003 | 03:37 AM
CL600_W140's Avatar
Cause I love the big body Mercedes Benz.. touch of class with lots of power... feels soo nice!!
Old Jul 24, 2003 | 11:21 AM
Davidta's Avatar
C230 Kompressor SPORTS COUPE
The 600 is a turbo is it not? Couldn't you chip it or install larger turbo's? If I remember correctly the new V-12 is just a de-tuned version of the engine in the Maybach, so with some tweeking should put out the same power.
Old Jul 24, 2003 | 03:18 PM
Dual 5Ls's Avatar
94 Wagon, 13 ML63
Nope, the 600 is a normally aspirated 6l V12, basically 2 3l V6s put together, like two 300E engines.
Old Jul 24, 2003 | 04:17 PM
Davidta's Avatar
From MB's website on the CL600
Engine Intercooled twin-turbocharged 5,513-cc SOHC 36-valve 60° V-12. Two-piece high-pressure die-cast alloy cylinder block. Alloy heads and pistons. Die-cast magnesium cylinder head covers.
Old Jul 27, 2003 | 07:51 PM
Dual 5Ls's Avatar
94 Wagon, 13 ML63
Yeah, thats the new one. I was talking about the "old" 600 engines. If he has the newer forced inducted engine, then yeah, I agree! Get a chip and redo the exhaust! If you want mondo power, up the boost to the maximun safe specs and see what kind of power you're pushing. Hehe, please include dyno graphs
