Kleemann s/c making noise
'99 CLK320 Cab Kleemann SC
I had a Kleemann S/C installed on my CLK 320 ~ 2000 miles ago. It developed a rattle, diagnosed as a water pump problem. The pump was replaced but the noise persists. It's only noticable at idle (while sitting in the car). Should the unit be silent or am I paranoid?
I've never experienced that kind of noise in my car or any of the other Kleemann SCed cars I have been in, however, I have only been in SCed V8s, not V6s. Nevertheless, it doesn't sound normal.
Re: Kleemann s/c making noise
New H2O pump is not seated fully into the driveshaft nose. Resulting in pulley bolts that appear to be tight but are not, allowing the pulley to rotate back and forth against the pulley bolts (fore and aft play) causing a loud ticking noise.
Previous water pump allowed excessive run out in driveshaft that allowed the drive couple to de damaged inside the SC transmission. Repair will require a bearing replacement in the transmission cover.
I doubt the second possibility as your third party mechanic verified the noise to be from the pump end of the assembly. The water pump replacement is tricky if you have never done it, I suspect this more than anything. In any case we will address the issue and fix it for you whatever it is.
Get it fixed/replaced under Kleemann warranty. Ask for a free rental while your car is out of commission. Kleemann is known for their top notch customer service. Demand nothing less.
1999 ML 430, BMW R1100s
Boy,
We all run in small circles, don't we??
Thanks for all of the replies, but the problem is being resolved by me and Brandon as it should.
I tried to talk the mechanic in Mass thorough the job, but he must have known a little more than me and didn't want to hear my words of wisdom.
I have done over 10+ units, new and taking one off and installing to 3 different cars.
I have NEVER had a water pump failure on the V-8.....only the V-6
I think we can all agree there was a problem here, but it will be solved shortly...Even if I have to fly from here to there to fix it! That is how I back up my products, even when they are purchased from someone else.
kleeman s/c noise
I'll back Benzmac on his commitment to Quality in his work. We both tried to get the MA mechanich to listen (to no avail). We're working through the problem. Kleemann USA has also been involved and is working with us. It's just bad luck. Would I do it again - sure, can't beat the performance though Kleemann should review the quality issues with the V6 units and come up with a root cause for the failures. If they can do it for the V8's they should be able to improve the V6.
kleeman s/c making noise
Another water pump was installed along with a new pulley. The noise is gone and we hope that this pump holds up (I was told its an improved design by Kleemann). The successful installation was acheived with the a lot of support from Benzmac.
Originally posted by benzmac
Boy,
Boy,
Now that the problem is solved and I have had time to look over all of the parts that were returned, I think the problem was an installation error when the water pump was fitted to the supercharger at the factory.
There is a press fit of sorts when the water pump sandwiches the supercharger pulley to the shaft. We think the water pump shaft wasn't seated fully and the bolts were then pulled tight. This caused a noise. The pulley was riding on the bolts that were tight, but the pulley wasn't sandwiched, so it clicked back and forth.
The reason for me explaining all of this isn't to point fingers but rather to shed light on the situation. I don't think it was a part failure or production problem, but rather a final assembly problem at the Kleemann plant.
So, from now on, I am going to take every one apart and check them before the installation.
Thanks for all that care.
And, I almost forgot. Doc, you kick but. I can't get over that you did this at home.!!!!!!!
HMMMM.....Let's see.
Immuneone IE.... A DOCTOR.![beat](https://mbworld.org/forums/images/smilies/beat.gif)
ps. Glad to here of the good things going on with your car! Good luck kicking a-- on the autocross track.
