Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
high fuel consumption and lagging acceleration
Old Aug 18, 2014 | 03:09 AM
karamoja's Avatar
W124 E220 M111
hi guys,
i need help on this. i recently got a W124 E220 M111. i noticed that it's fuel consumption is abnormally high, almost at the rate of 2 KM/L.
the vehicle also has lagging acceleration. the pedal is hard when pressure is applied and after it picks there is a slight over revving.
i don't know whether this is tied to the consumption or they're two isolated problems.
kindly assist
Old Aug 24, 2014 | 02:40 PM
GotDaBenz's Avatar
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
How are the rpm's? If they are high it could be tranny.
Old Aug 25, 2014 | 04:01 AM
karamoja's Avatar
W124 E220 M111
the rpm's are ok so far..the only thing i have noticed is, sometime's when the accelerator is pressed the rpm's jumps to almost 2700 even after releasing making that over revving noise
Old Sep 17, 2014 | 06:36 PM
cortschrothNJ's Avatar
1999 E320 4Matic Sedan
has the car ever felt like it was going to stall after coming to a stop from cruising speeds?
Old Sep 17, 2014 | 11:46 PM
karamoja's Avatar
W124 E220 M111
Yes it does...rpms going down to 500,so the car struggles to stay on
Old Sep 18, 2014 | 04:06 PM
if the check eng. light is on also i could have something to do with the torque converter clutch solenoid, if the torque converter clutch isnt completely disengaging it can cause the car to stall coming to a stop and would also contribute to poor acceleration. I mean it could be sensor also i would definitely check for dtc's and let that lead to a more specific diagnosis
Old Sep 25, 2014 | 06:36 PM
corsaschnell's Avatar
S65 AMG
Several things can cause this. One possibility is a bad EVAP purge valve, in my case that was the cause. Luckily the CEL came on and Dealer was able to get a code and resolve it.
Old Oct 10, 2014 | 09:14 AM
oldsinner111's Avatar
s320
check your vacuum hard lines.My MAP Sensor wasn't plugged into vacuum.
