Spark Plugs on E55
My first steps are K&N air filters, MAF and TB ( I don't even know MAF and TB can be done in this car). Then I'm also curious about the spark plugs, I've successfully used Bosch Platinum 4 on my vehicles getting up to 3 tenth better performance (excellent for 5 bucks a spark plug)
Here is the question: How do you remove the spark plugs
and does anybody recommend a particular brand??Thanks in advanced for any replies.
Usually bigger is better, up to certain point, I've always changed these two items to GM vehicles with excellent results, so I don't know if this is doable on these cars.
NGK platinum are supossed to be good plugs, but I've never been a fan of them after having Bosch Platinum 4 on my cars, there is so much difference, it is hard to belive that those spark plugs can make that much difference.
mbtech, I know how I'm supossed to do it, but I don't know how to remove the metalic cover off of the spark plug wires, do I twist it? is there a special tool?
So at this point I'm not sure what to do, depending of what I find when I remove a plug I'll make my desicion of what to try.
pocholin
Did you ever change the spark plugs in your E55? If so, what brand and gap?
Thanks. I think I'll have my spark plugs replaced with the OEM plugs, which on my 99 E55 are NGK platinums.
The car has 39k miles and has never had the plugs replaced. Its hard for me to believe that the plugs do not be changed or that the car would not benefit from new plugs. From what I see under the hood, there is nothing unusual or difficult in changing the plugs. I never asked the dealer here about the cost to change the plugs b/c I thought I would do it myself and save some $$$.
I think the ones on the driver side towards the firewall are going to be the most difficult.
In any event here is a helpful hint to removing the plugs. The plugs themselves are easy- getting the wires off the plug is the tough part. HEYCO and others make a valve adjustment wrench for older MBZ- this wrench is perfect for removing the wires. Its a 19mm throat on the end of an S bent wrench. The throat of the wrench fits just behind the ridge of the metal boot right at the wire. Levering against the cylinder head pulls the boot right off. Using a standard 19mm open end wrench is also possible.
