Performance Upgrades & Tuning Discuss general performance and tuning enhancements for your Mercedes-Benz.
Schrick Camshafts available for most Mercedes models!
Old Mar 24, 2004 | 07:26 PM
Mach430's Avatar
We have been told by reliable sources that Schrick makes the same cams for all Mercedes tuners as those they sell publically.
Have we verified this? No.
What I can tell you is that Schrick is the #1 cam builder for the euro aftermarket industry, and that they are the cam builder of choice for many euro tuners. Further, have seen the same gains from Schrick cams that other Mercedes tuners advertise, which supports what our sources have told us.
If you'd like to discuss this further, feel free to call me.
Regards,
Ben
Old Mar 24, 2004 | 08:57 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
Thanks again for the info
Old Mar 24, 2004 | 10:21 PM
Mach430's Avatar
You're welcome!
Old Mar 25, 2004 | 05:05 AM
Twinturbo's Avatar
Just curious, since the Merc engines do not have variable cam timing, to get an increase in peak power will this not lose the bottom end power and hence the flexibility of the engine. I think that unless you seriously want a power increase and are always driving your car hard, those cams would be a compromise. Any opinions on this?
Old Mar 25, 2004 | 02:40 PM
speedybenz's Avatar
AMG C43, 1999
Hi Ben,
Any dyno data for the V8 cams yet?
Drop those babies in your CLK and give us some data!
Jeff
Old Mar 25, 2004 | 02:45 PM
speedybenz's Avatar
AMG C43, 1999
Twin Turbo,
The cams have the potential to increase power everywhere as the stock cams have to be made to accomidate smog reg's of not only a new car but one with 80,000 miles and such. So cam lift and duration can have a large effect on smog emmissions.
By focusing on performance and letting smog concerns remain, but not as a strong focus, it's possible to build a cam with more lift and slightly more duration and with faster ramp opening speeds to create more Hp.
Jeff
Old Mar 25, 2004 | 04:38 PM
  #32
Mach430's Avatar
Jeff,
Dyno numbers from my car wouldn't do much good, I have a blower You should expect 20hp at the wheels on your C43.
Regards,
Ben
Old Apr 2, 2004 | 03:10 PM
  #33
kimber45's Avatar
2001 CLK-430 Black
Who can I talk to about a powerchip for my 430? And are there any good shops in NJ/NYC that really know MB Performance?
Thanks in advance
I figure:
Powerchip
CLK55 Airbox
Free flow Exhaust
I will be good to go with the best of them!
Old Apr 2, 2004 | 08:01 PM
  #34
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Thanks in advance
I figure:
Powerchip
CLK55 Airbox
Free flow Exhaust
http://www.evosport.com/product/perf....html#software
Old Apr 24, 2004 | 11:16 AM
  #35
AMG///Merc's Avatar
03 CLK55
I've heard the same thing...
Regards,
Ben
I'm sure that they're Schrick cams. I don't think that any MB tuner could justify the manufacturing costs for the relatively few cams they would sell. Regardless, Schrick cams are absolutely beautiful pieces. Anyone who hasn't seen their website should check it out!
Speaking of MKB, does anyone have any idea how much their full NA set-up (cams, headrs,exhaust ecu) costs? I imagine that for the money, it might make more sense to go with a Kleeman supercharger, but I like the idea of a wicked na motor. Has anyone heard of anyone using a Kleeman compressor with MKB cams, headers, and exhaust? I imagine that would be awesome , but I have to think that neither ecu would work well with that combination...
Best regards,
Matt
Old Mar 5, 2005 | 10:26 PM
  #36
SouthernSon's Avatar
'81 380SL/dual cam chain-LT4 vette-Z06 ('03) vette-I need a bigger garage....
After the initial outlay of $2500 for the pieces, the labor of installation....$2000?, $1000 for dyno tuning and then more money for the few extras that 'might as well replace while in here'.........
Even at an honest 20HP at the rear wheels it is just a little steep don't 'cha think?
Old Mar 6, 2005 | 02:24 AM
  #37
tery's Avatar
CLK320
here is my schrick cam when i got year ago. Install took 1 full day. With ECU and cam it works very well.
Attached Thumbnails Schrick Camshafts available for most Mercedes models!-028.jpg
Old Mar 6, 2005 | 09:41 AM
  #38
I installed the GM HOT camshaft in my vette a couple of years ago. The cam was only a couple of hundred but in order to make everything work together, one needs to open up the air intake, possibly go to bigger throttle body, a good set of headers always helps and then look at high flow catalytic converters/ exhaust system. The total bill for the above items, with no labor costs since I did the work myself, came to over $4000. I picked up 50HP and 40 torque at the rear so I am happy. If I had just done the cam, personally, I would not consider 20HP worth it. Of course, if one does just the cam only, I am very suspect of 20HP to the rear.
Old Apr 7, 2005 | 02:58 AM
  #39
JLee81's Avatar
04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
what's the angle of the cam?
Old Apr 7, 2005 | 11:45 AM
  #40
tery's Avatar
CLK320
http://www.schrick.com/
u can find it on here
Old Apr 25, 2005 | 12:48 AM
  #41
steve872's Avatar
2003 Slk230
Can you find me a camshaft for my 2003 SLK230.
Old Jan 17, 2007 | 03:56 AM
  #42
Ben'z's Avatar
E320
Anyone have the part numbers of Schrich camshafts for M112 motor?
Old Jan 19, 2007 | 07:22 PM
  #43
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Schrick cam part Numbers
For the Mercedes M-112 engine
0351 01 561- LO thats Left hand order / Driverside
0351 01 561- RO thats right hand order / passenger side
Take care ___PTE___
Old Jan 20, 2007 | 03:33 AM
  #44
Ben'z's Avatar
E320
Thanks a lot!
Take care ___PTE___
Old Jan 20, 2007 | 07:22 AM
  #45
WaveyKat's Avatar
Something Slow
where are u getting them from?
Old Jan 20, 2007 | 01:19 PM
  #46
bejak's Avatar
2004 SLK200K R171
Could not find any Mercedes information at Schrick. Searching for cams for my SLK200K, the M271 motor. Does anyone know something about this?
Old Jan 20, 2007 | 01:42 PM
  #47
Ben'z's Avatar
E320
I have contacted Schrick in German, no answer...
I tried to call many turners in the US, got some response said, they will look for it for me...
Any advice?
Old Jan 20, 2007 | 01:50 PM
  #48
2PHAST's Avatar
500E Signal Rot
Anything available for the M119?
Old Jan 21, 2007 | 11:31 AM
  #49
WaveyKat's Avatar
Something Slow
Any advice?
if u can find a place that sells it please let me know thanks
Old Jan 21, 2007 | 05:58 PM
  #50
JLee81's Avatar
contact any racing shops around your area. Most racing shops can order schrick camshafts.
