"Warning" about having your car "tuned" off-site
I could just send them my fuel-trim readings and wide-band readings and they could perform magic.
Well I have spent the last two or three days with my new A/F calibrator with my new injectors.
I have driven all over Long Island watching my A/F and short and long fuel trim. Watching each rpm range, vacuum range, fuel trim, idle map, cruise map..
I made at least 5000 changes on over 30 tunes to get the car running with a -.08 long term fuel trim and a short term trim that hovers around 0.
My mph has gone up considerably as well.
I have not even gotten to the boost range yet as I am just using factory settings and letting the bigger injectors take over.
A good tuner will tell you they need to have the car for the day(at least) and it has to be tuned on a dyno for WOT.
I am now convinced of this.
When I just installed my Supercharger and let the ECU "learn", I didn't realize that I was pegging out the system in certain areas.
That is why I had flat spots. Especially coming out of third gear.
Now the car is smooth all the way to redline.
Just my thoughts on something I am sure everyone has thought about doing. Calling up for the magic chip and then getting 40hp over the phone.
Powerchip wanted my car there and now I see why. Especially with all of my mods. The guys in Maryland said they could do it off-site and send it to Austria.
I am not endorsing Powerchip, I am just saying that did not want to take a stab in the dark and I respect that.
It is alot easier figuring out the information on an oscilliscope from the crank signal than it is to decifer hex code.
I will post my track results as soon as I go. Hopefully this weekend.
Will do. The next project is to figure out how to retard the timing on boost, piggyback style.
