Kleemann, what's next???
Now that I have my pulley kit installed, I'm addicted to the power. But, like other addictions, its never enough!! What is the next step for more power? Do you make an intake camshaft?
Yesterday I sent a intercooler company lots of pictures and measurements of the factory intercooler. I'll give them a call mid week after they had a chance to absorb the info. They are eager to produce it.
Also, what Kleemann kit did you install? The ring or pulley? The pulley should get you 8hp more according to Brandon. Let me know if you are interested in our alloy pulley group buy. We have about 26 people on the interest list and the current price for the alloy pulley is $350 and installation is a do it yourself job (changing the light bulbs took me almost as long).
There is almost nothing to be gained from an open element airfilter or "cold air intake"- the major restriction in the pumping system is insdie the throttle box. Ex systems bring nice noise to the table but I have yet to see one that brings any power worth talking about ( 2-3hp just doesnt cut it as this can be machine error from the dyno).
4 to 2 to 1 ex header may be worth looking at too- MBZ manifolds are not exactly tuned for maximum attack.
Of cource the intercooler is another obvious place to look- most of the available soulutions will set you back $3K plus- Im assuming you want something a little less brutal than that. Air density is where its at however- a general rule of thumb is that for every 10 deg F you can reduce intake temps you have the potential for 1% more power. You do the math!!
Does anyone know if there are any differences between the pre-2000 SLK230 intercoolers and the ones in the newer SLK230s or C-Coupes.
Also, does anyone know if there's a sensor that measures air intake temps on the C-Coupe or SLK that you can read with an ODBII scanner?
ReigerSLK installed a custom intecooler with a core from Spearco (the core costs $380). He had someone make the end tanks and attachments. It's 4 1/2" thick compared to the factory 2" thick intercooler.
Both old and new M111 intercoolers make great door stops- one is not better than the other.
A thick core does not make a better intercooler by default. Minimal pressure drop and high tube/fin density are what you are looking for. The SPEARCO core undoubtedly works better- but so would a wet rag compared to the standard IC.
So who's the king of intercoolers (at a reasonable price)? I like Spearco only because they are local in Los Angeles. I've sent them the specs on the factory intercooler hoping they would suggest something. Thicker is easier as there is room and it maintains the same frontal area and hopefully the duct work will still fit. Also contacted a company called fluid control products as they only do low volume custom work. Evosport said they are working on it also. I think there is going to be a demand after everyone that has a pulley get's bored and asks what's next. Chipping is the next best bang for the buck but the intercooler is the next big power jump for the buck after that.
I'm only interested in getting an intercooler for myself and few interested people on the forum but I can tell you that none of us will spend $3,000 for an intercooler let alone what Renntech or Vaeth wants. I'm hoping for under a $1,000 similar to what's sold for other forced induction cars.
Also, does that Fluke sensor replace the factory sensor?
The FLUKE is a handheld meter like a DVM that reads K type thermo couples- it does not replace the stock sensor (its insdie the MAF in any event). Air temp effects density so it is an important aspect of the air mass calculation for the ECU.
Randy
Use an adjustable HOBBS pressure switch (teed into manifold after TB and set to your favorite boost pressure) that trips a relay to run an additional windscreen pump (teed into the outlet from the washer tank).
Presto- boost sensitive additional cooling.
ON/OFF switch inside to activate/deactivate system, since you probably only want this function for "battles" (otherwise you might go through quite abit of blue goo.
I called Renntech and Oberklasse and neither would sell an intercooler without their kit.
Cute idea with the windshield washer motors. The new Subaru STI will have factory sprayers as standard equipment for their intercooler.
