Questions about how MBWorld.org works...not for car questions. Use this forum for help on using all or any part of the forums. Make sure to read the Forum FAQs first.
C200 Kompressor Sports Coupe - engine failure
Old Aug 11, 2012 | 05:32 AM
sandyone's Avatar
2003 C200 Kompressor sports coupe
2003 model with 45,000 on clock: serviced at correct milages:
The car died last week and was towed to a Mercedes Main dealer:
After a £80 diagnostic check and compression test:
A £1850 provisional estimate given for renewed inlet valves; timing chain and tensioner: With a option to inspect damage when dismantled: and old parts to be kept.
There was a U turn on the inspection with some rather lame excuses:
I found this rather suspicious:
Car sorted and now going: Work necessary as anticipated:
I don’t seem to be getting a clear explanation of the cause of the mishap, other than a tensioner failure: The timing chain was intact, but had jumped a few teeth [There were no unusal rattles/noises from the engine prior to the failure: was travelling along a quiet road at 25mph ish]
The tensioner does not appear to be seized and the oil holes appear clear:
Has any one any thought on this matter ?
Peter Clare
