R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
R350 Engine RPM to0 high?
Old May 8, 2008 | 08:17 PM
AsianR350's Avatar
08 R350, 12 Mercedes R350
Is this normal for R350 engine 2k RPM @ 60 MPH?
What is the mileage engine break in?
(Mine is just over 100 miles on the odometer)
Thanks,
Old May 9, 2008 | 07:10 AM
PartyVan's Avatar
2013 C63 Coupe P31 2021 GLC63s Coupe
2k rpm at 60 mph seems a bit too high, my E500 with 5 speed only revs to 2k at 80. I am guessing it is doing so because your car is still brand new and the adaptive tranny is still learning your driving style. My guess is wait till you hit 1k miles and if it is still reving that high take it in to your dealer to have them check it out.
Old May 9, 2008 | 12:45 PM
AsianR350's Avatar
Thanks,
Anyone else who own R350 likes to jump in on this question.
Old May 12, 2008 | 07:38 AM
Scotsman's Avatar
2004 SL500, 2007 R350 Sport
I'll check out 60mph but at 80mph it's about 2500. My SL is about 2000 at 80mph so the R must have different gearing.
Old May 21, 2008 | 09:31 PM
benzlvr2500's Avatar
gets me from point A-B
my R350 has 5000 miles on it and @60 mph, it still hits 2k rpms so I dont think mileage has anything to do w/ it
Old May 21, 2008 | 10:06 PM
AsianR350's Avatar
Thanks for the info.
It seems 2K @ 60MPH a little bit high compare with some other cars.
Old May 23, 2008 | 11:23 PM
lkchris's Avatar
'10 CL550, '12 GL550
The answer to your question is painfully simple.
Your transmission is either shifting to 7th or it's not.
Comparison to cars other than Mercedes is irrelevant.
Old May 26, 2008 | 10:38 PM
JTReeves's Avatar
2007 R-500
Re: R350 RPM Too High
I remembered to check my tach today while on the highway. I was driving right at 60 mph and saw my tach saying just less than 2k RPM. My car is an R500 and sports about 20,000 miles. In my humble opinion, 2k RPM is normal for that speed.
JR
Old May 27, 2008 | 06:21 AM
AsianR350's Avatar
Thanks forthe info.
With R500 (V8), you should get less than 2K RPM @ 60 MPH.
At 80 MPH, I got over 2500 RPM.
Old May 27, 2008 | 06:57 AM
AsianR350's Avatar
Thanks forthe info.
Old May 27, 2008 | 05:33 PM
JTReeves's Avatar
2007 R-500
Smile
Originally Posted by AsianR350
Thanks forthe info.
I won't get to check until Friday when we take a road trip to NY. I'll check the rpm @ 80 mph to see what it is. I recall that, at a steady cruise of 80-85 (my normal speed when traffic allows on road trips) the engine speed isn't too far from 2500 rpm.
Old May 28, 2008 | 10:02 PM
bcbit01's Avatar
E60 545i
R350 RPM at 60
You shoudln't try to compare the R350 to the R500 in this respect. The 3.90:1 Final Drive ratio is the same for all R350's (2WD or AWD) but is not the same as the R500's 3.70:1 (only availablie in AWD). Power is also vastly different between the two (268hp/258 lb/ft for the 350 vs 302hp/339 lb/ft for the 500) and, trust me, all these factors will make a difference when the two cars only weigh 179lb apart. I checked a couple magazine reviews and engine RPM at 60 mph was 1900 on the two reviews that listed the stat. As far as break-in mileage, engine speeds at a given road speed will lower after break in but not enough that you could possibly notice without a digital tach....maybe 25-50 rpm...and can vary even more than that value with differences in ambient temperatures, humidity, engine temperature, and payload. I'd say you're in the clear and should worry about something else like saving for your 30,000 mile service.
Old May 29, 2008 | 11:52 PM
PartyVan's Avatar
Judging by the posts 1.9k rpm at 60 seems to be the normal speed so this got me thinking, could it be the 4 matic gearings that makes the tranny rev so high? It would be interesting to see what the 2 wheel drive version reves at 60...
Old Nov 3, 2009 | 06:58 AM
hotflyer71's Avatar
R350
R350 7th gear ratio is 0.73 and final drive is at 3.7 (3.9 is for the R280) using online calculator with tire size gives 102km/h at 2000 rpm....
Old Nov 9, 2009 | 07:17 PM
smokersteve's Avatar
06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
Thanks,
I have the 7-speed and you could still be in 6th gear while you going 60mph.
Old Nov 21, 2009 | 03:30 AM
hotflyer71's Avatar
R350
Correct.. And so, I take a higher speed at 80mph and found the rpm to be 2200
Old Nov 29, 2009 | 09:26 AM
AsianR350's Avatar
Same as yours now.
My R has 8000 miles on the odometer and at 80MPH, the tachometer shows 2200 RPM which seems less than when it was new.
