Power rear hatch reliability? Should I be worried?
This brings major concern to me regarding the hydraulic mechanism that raises and lowers the power rear hatch. I love the feature and so does my wife, but as with the hydraulic power soft tops on the old SL roadsters, I wonder if constant use will eventually blow the seals and leave me witha costly repair. Being that the R's came out in '06 if nobody has had any issues yet only time will tell. Just wondering if anyone has ever had this part quit? Mine isn't broke and works flawlessly I just don't have a lot of trust after the R129 SL experience.
I talked to the dealer service professional in Madison WI and he said that there has yet to be 1 power lift that needed service yet.
The only issue he brought up was the latch mechanism will need adjustment from time to time - which they called normal.
My service rep sends out a satisfaction survey each time I take the car for servicing. He insists that he must be rated "excellent" in all categories or there will be negative consequences for him. On the days that I ask for the hatch operation to be fixed, I don't bother responding to the survey since I can't rate him any higher than "unsatisfactory."
JR
It's kind of like tires--you know they'll wear out and you call replacing them "maintenance." Same with your "seal."
Yes, tires are for sure a "known issue."
The 43 year old top seal on my GTO still keeps water out despite showing signs of it's age. I'd expect a leak on something made by Kia or Hyundai in that timeframe.
Failing after 10 years is the result of Mercedes outsourcing to Mexico.
I took it back in and they replaced a pinch sensor as well as adjusted the latch again and it has worked everytime - so you may want them to check that out.
They also seemed to have found the sunroof noise gremlin - all just as the regular warranty ran out. Hope I never have to see that Chrysler Town and Crappy rental thing again.
1. About half the time you try to open it, it whirs, clicks, moves a half inch or so, then re-locks. Sometimes takes two or three tries to get it to open.
2. Not quite so often, but still frequently enough, it won't close - closes, whirs, clicks, opens again.
Every single time it's been in for service I've asked it to be fixed. They've adjusted it multiple times, changed microswitches, last time they replaced the motor - no charge, even though it was out of warranty - I insisted it was a warranty problem that had never been fixed, they accepted that. Made no difference.
I've just about given up. I think I'll give it one more try and escalate to MBUSA, since the dealership (MB Larchmont, NY) seem to have run out of ideas. Any thoughts?
Mike
