Oil Brand for Mercedes R 320 CDI
Searching the internet I found different oil types and viscocity: mobil 1 0w30 or mobil 1 5w30, castrol slx 0w30.
I would like to know what your dealer use for your 320 CDI.
Your car requires very special motor oil that meets Mercedes specification MB229.51. 229.51 MUST be printed on the bottle or otherwise the oil withing does NOT meet the specification. 229.5 is NOT the same as 229.51
Anything else will poison your very expensive diesel particulate filter and if you do that with the wrong motor oil it will NOT be covered under warranty. Read "anything else" to mean don't add ANY QUANTITY of anything else, for example a quart between oil changes. My GL has an underhood sticker with this warning, but not sure about R. It applies whether sticker is there or not, of course.
For all intents and purposes in the USA you are limited to Mobil 1 Formula M ESP 5W-40, which is available at Mercedes dealers and PepBoys and hardly anywhere else. (ESP means emissions system protection)
BTW, your dealer must have misunderstood that you have a diesel, because the 0W-40 Mobil is the wrong oil for your car. It's only 229.5
There are some diesel engines that have DPF that need mobil 1 ESP.
I go for 10,000 miles between changes and maybe add 1.5 - 2 quarts between changes.
I've had no issues.
If only 320 CDI is that the same case with all 320 CDI on all other models of mercedes.
I do not think my 1.5 - 2 quarts for every 10,000 miles is excessive.
To add a question to yours, does synthetic oil have the same consumption rate as conventional oil?
The thinner the oil the more it is likely to burn, 0W30 being the worst. I try to use 5W40, it is the thickest available in low saps around here. I have never had to add oil yet, almost through two services so far. I don't use much power either though and always plug it in when cold.
- 9.5 Quarts of Castrol Edge Professional OE Full Synthetic 5W-30, MB229.51: $81.08 (tax included for 10-quarts)
- 1 Mann oil filter - HU 821 X Metal-Free: $12.21 (all in from Amazon)
- 1 Oil Change fee for carry-in: $25.50 (tax included)
- $10 tip to the pit tech to properly manage the pan cover and drain plug removal and re-install
I hope this is useful info. Again, if you have info to add or see any issues with my oil selection, please let me know.
Good luck and enjoy your 2007 R320 CDI
-FIBERTOWNER
http://bevo.mercedes-benz.com/bevoli...51&suchbegriff=
