R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
New installed LED H7 Bulb on foglight
Old 10-30-2010, 08:50 AM
AsianR350's Avatar
08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
Parts requirements:
- 120 SMD Leds H7 Bulbs-6000k X 2
- 6 Ohm 50W Load Resistor X 2
No warning bulb out on cluster.
Here are the pictures.
Attached Thumbnails New installed LED H7 Bulb on foglight-img_0282-desktop-resolution-.jpg   New installed LED H7 Bulb on foglight-pic-012-desktop-resolution-.jpg   New installed LED H7 Bulb on foglight-img_0284-desktop-resolution-.jpg   New installed LED H7 Bulb on foglight-img_0279-desktop-resolution-.jpg   New installed LED H7 Bulb on foglight-img_0280-desktop-resolution-.jpg
Old 10-30-2010, 11:10 AM
AsianR350's Avatar
Full front shot & new tail LED strip lights
Here is the final front shot with new tail LED strip lights.
Attached Thumbnails New installed LED H7 Bulb on foglight-img_0285-desktop-resolution-.jpg   New installed LED H7 Bulb on foglight-img_0290-desktop-resolution-.jpg
Old 11-13-2010, 02:51 AM
cyeung65's Avatar
Q & R
Tell me more about the rear strip LEDs. Are they installed inside the lens?
Old 11-13-2010, 12:37 PM
AsianR350's Avatar
It is Side Glow LEd strip lights and it mounted from top/outside the len.
Here is the link:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Attached Thumbnails New installed LED H7 Bulb on foglight-img_0294.jpg   New installed LED H7 Bulb on foglight-img_0293.jpg
Old 11-13-2010, 01:30 PM
M-bENZ's Avatar
Corrolla
so is there resistor came with the LED ? im talking about the foglight LED here .
Andy
Old 11-13-2010, 01:48 PM
AsianR350's Avatar
Andy
You have to buy load resistor - 6 ohm, 50 Watts ($10.00 for a pair)
Old 11-13-2010, 03:34 PM
M-bENZ's Avatar
Corrolla
Thank you sir.
Andy
Old 11-15-2010, 10:12 AM
shobbs666's Avatar
2006 R350
WOW! They look GREAT! Can you let me know how you wired them to the rear array without getting a "Message" for rear lights? I have a 2006 R350 and really want to do the same. Thanks Steve
Old 11-15-2010, 12:53 PM
AsianR350's Avatar
First, splice (solder) both led strip lights together. (+ to +, - to -). Pre test LED strip light to find out which wire is potitive and which wire is negative.
Ground one wire of LEd strip light to chassis ground (there is one near inside the gas tank door). The positive wire of LED strip light to the gray wire of rear tail light connector (the first gray wire (pin #1) look from the rear of connector).
Note: I connected in line 2 Amp fuse to the postive wire before inserted into the back of pin 1 (I put more solder onto the stripped wire and inserted from the back of connector so it will snug contact with pin 1 connector)
I will take the picture of the gray wire of rear tail light connector which I inserted the positive wire of LED strip light to.
Old 11-15-2010, 02:32 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I like the LED fogs. Do you have any pics/info and how/where you spliced in the resistors?
Old 11-15-2010, 02:35 PM
shobbs666's Avatar
2006 R350
Thanks, for taking the picture to show me. When you say- First, splice (solder) both led strip lights together. (+ to +, - to -). Does that mean it's two strips per side?
I love what you did to the front fog lights as well. Any ideas on what I could do to put some sort of white strip lites in the front. The problem is I don't have fog lights. I think the wires are there in the harness but there's something about reprograming the computor to activate them? You seem to be the lighting pro here!! Thanks again Steve
Old 11-15-2010, 05:46 PM
AsianR350's Avatar
One strip per side.
When you wire them parallel, they will be on the same time.
You can wire each LED strip light separate but you have to to connect each light to brake light (left and right).
You can also connect to top center LED light if you can find the wire behind rear molding wihout removing the top panal hatch back.
For the front, you can connect the LED light or LED strip light to side marker to turn it on.
Here are the pics as I promised.
- Gray wire is for the brake light that tied to the new red positive wire from LED strip lights.
-Ground location for negative wires from LED strip loghts.
- Wires via rubber molding at the bottom chassis that lead to inside spare trunk.
Attached Thumbnails New installed LED H7 Bulb on foglight-pic1.jpg   New installed LED H7 Bulb on foglight-pic2.jpg   New installed LED H7 Bulb on foglight-groundpoint.jpg   New installed LED H7 Bulb on foglight-wiredtosparetrunk.jpg
Old 11-15-2010, 05:49 PM
AsianR350's Avatar
The load resistor is wired paralell to the existing OEM harness (one to the postive and other to the negative)
Note: Resistor does not have (+) or (-), so wire it any way you want.
Old 11-15-2010, 06:09 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Thanks, I appreciate it.
Old 11-16-2010, 07:42 AM
shobbs666's Avatar
2006 R350
Thanks for everything. As soon as I'm done I'll send you the pictures!
Old 02-06-2012, 05:29 AM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
Resistors get hot....is there a different resistor size to use to avoid too much heat? Would a larger resistor make it warm to the touch?
Old 02-06-2012, 06:18 AM
AsianR350's Avatar
Why would you want to touch as well as touch the bulb?
As you can see the first post, the load resistor is heat sink fin aluminum and mounted to metal housing bulb holder so the heat will dissipate to metals without burn anything.
Old 02-06-2012, 06:19 AM
AsianR350's Avatar
Why would you want to touch it as well as touching the bulb?
Old 02-10-2012, 03:42 PM
tmaj12k's Avatar
r 350
Any idea if those h7 bulbs would work for the low beam?
Old 02-10-2012, 05:57 PM
AsianR350's Avatar
It will work but no intensity very low means it will not bright enough to help you see the road.
Aftermarket HID is much better, I have 55W 4300K HID on low beam and much better than OEM 35W halogen.
My fog lights now is 35W HID now and see the road much better than OEM or LED light (this LED is just for white color but not for brightness)
Old 08-01-2012, 09:30 AM
GLO
GLO's Avatar
W205 C250BT & R320cdi-L V251 (sold c220 cdi Elegance)
Hi,
Have you tried the Cree LED bulbs? And do you think this would provide more light than your HID?
Old 08-01-2012, 12:55 PM
AsianR350's Avatar
All LED bulbs are not bright as HID xenon bulbs due to lower current (power) draw.
I have already changed my fog lights to HID xenon and much brighter like the low beam light.
Old 08-05-2012, 12:07 PM
Luca10's Avatar
2008 R350
Question
Hey Asian
I'm new to this forum. I'm getting a 2008 white R350 and want to update the lights with LEDS. I want to change the daytime light bulbs which is easy. What size bulb did you use? I see you changed the fogs. Did you replace the whole light or can just the bulb be changed? You said you used an H7 bulb for the fogs, where did you buy it?
I'm changing the wheels to 505's from a CLS500, should look hot. I'll post pics.
Old 08-05-2012, 12:33 PM
AsianR350's Avatar
Originally Posted by Luca10
Hey Asian
Just the bulb. (ebay)
Old 06-21-2013, 11:43 PM
GLO
GLO's Avatar
Hey AsianR350,
Do your LED Fog bulbs have Active Turning assist where the fog lamp lights up as you are turning into that side? ie do they light up when you are turning left or right? And ifso, do the LEDs have variable intensity? or only ON or OFF?
Quick Reply: New installed LED H7 Bulb on foglight
