R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Tranmission and Limp Mode
Old Dec 21, 2010 | 10:26 PM
Redlight's Avatar
2006 R500
For the past few months our 06 R500 has been experiencing very intermittent transmission issues. Usually once every three weeks upon stopping at a light or stop sign the car enters limp mode. If the car is turned off and back on the issue goes away. I have yet to take it to anyone as I don't know if they can replicate the problem but am wondering if the computer is throwing any codes. My brother, who used to be a Mercedes mechanic believes it may be a bad speed sensor. Has anyone heard of this problem before or knows if there are there any known issues? The car has just over 44K on the odometer.
Old Dec 21, 2010 | 11:44 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
There is a new DTB out which one of the symtoms is the speed sensor code.. Is it settng the check engine light when it goes in to limp mode? Have you had some one scan for codes yet?
Old Dec 22, 2010 | 09:52 AM
Redlight's Avatar
2006 R500
No, it isn't throwing any check engine lights and my brother is able to scan for codes, just haven't made it up to his shop yet.
Old Dec 22, 2010 | 09:55 PM
hcetzneb's Avatar
Are you sure your in limp home mode? The tranny in your car (722.9) is very sensitive if it goes into limp mode, 2nd gear only it will store a code with a check engine light. Is there any way you are hitting the up/down shift buttons behind the steering wheel?
Old Dec 28, 2010 | 11:51 AM
anjy834u's Avatar
Mercedes Benz S 550
u need to check the transmission liquid and the transmission mount. these are the basic troubleshoot steps for a transmission issue.
Old Apr 17, 2011 | 11:34 AM
Twells1212's Avatar
2007 E350
Did you ever resolve this issue? My 2007 E350 has had 3 instances of this over the past few weeks. Turning the engine on/off resolves it, but am wondering if you its the speed sensor or tranny issues? You get your codes checked?
Old Apr 17, 2011 | 01:41 PM
Redlight's Avatar
2006 R500
Twells1212,
Yes, were were able to get the problem fixed. About a month and a half ago, after doing this for quite a while, the vehicle got stuck in limp mode and would not come out of it regardless. I can almost guarantee this is the same problem you are facing as Mercedes immediately knew what it was without even looking at it. In the transmission valve body, there is a conductor plate that will need to be changed. Mercedes is the only one that is able to work on this and our out of warranty cost was $1,650 (out the door). I would highly recommend taking care of the problem sooner than later before you get stuck somewhere. Good luck.
Old Apr 17, 2011 | 06:15 PM
smokersteve's Avatar
06 R360, 06 F350 6.0, 04 CayenneS, 96 911TT 500HP, 86 928S, 74 911S, 73 914-4, 70 914-6, 02 Durrango
Can you put an attachment on here of the work order?
Old Apr 17, 2011 | 09:15 PM
Redlight's Avatar
2006 R500
Yes, I am currently out of town on business and will return next week. Knowing that this is a common problem with the 722.9 transmission, hopefully it will help people in the future.
