R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Replacing my Oil Cooler line with pic
Old Feb 7, 2011 | 11:55 PM
dewdaltz's Avatar
02ML320/06R350
The cooler line has a leak but not that bad,(see pic with red circle) the one from the transmission to oil cooler. Do I need to drain the oil before I could replace the whole line OR can I just loosen that bolt and put right back? Share your thoughts on these.
Old Feb 8, 2011 | 07:12 AM
rcompart's Avatar
2005 C32 4Matic - That's Not A Typo! :D
Is it leaking from the fitting, the hose or the pipe?
Old Feb 8, 2011 | 08:12 AM
shobbs666's Avatar
2006 R350
It will drain out when you replace it anyway. I would drain before you repair the hose to avoid a mess. You will need the replacement bass ring for the trans plug and new fluid.
Old Feb 8, 2011 | 09:05 AM
dewdaltz's Avatar
02ML320/06R350
the leak is between the rubber thing and tube. see pic with red circle. Thanks for your input.
Old Feb 8, 2011 | 09:07 AM
dewdaltz's Avatar
02ML320/06R350
I am sure I have to replace all the necessary O-ring and the likes all at once. what kind of oil is being use on this - transmission oil?
Old Feb 8, 2011 | 10:06 AM
shobbs666's Avatar
2006 R350
Mobil/1 qt. synthetic automatic transmission fluid This is what I use.
Old Feb 8, 2011 | 10:32 AM
dewdaltz's Avatar
02ML320/06R350
thanks. one more thing how/where do you add the transmission fluid?
Old Feb 8, 2011 | 11:07 AM
shobbs666's Avatar
2006 R350
Add it using the dip stick tube you will need a funnel that fits. Also the transmission will have to be around 100 deg. before you can top off.
