R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
THINGS I DIDN'T KNOW ABOUT MY R CLASS
Old Aug 27, 2018 | 03:02 PM
  #76
BCS13's Avatar
2008 R350 & 2011 E350 Cab
Fuses
Another tip for R class owners. I have an 08 R350.
(148K virtually trouble free miles )
Tip:
By no means ever store anything that may leak liquid, in the
rear storage area. The fuse box is located under the access
door for the spare tire and liquid will find its way into the compartment.
There is a cover of sorts over the fuse box but it didn't help much.
I found out the hard way when my cooler
full of ice started leaking water and shorted out a couple of fuses.
Fortunately is was minor and cost only $150 for the fix. My mechanic said it could of been much much worse !
Old Nov 2, 2018 | 02:26 PM
  #77
R3504Matic's Avatar
2006 R3504Matic, S430, BMW750E66, E350 207, PORSHCE 911C4S, BMW128 E88, VWTREG, 86 560SL, 88560SEL++
Originally Posted by houseofdiesel
If you install BIG wheels, the airmatic suspension will compensate for ride harshness after a few trips. I went from 18" to 22", it was terrible the first day and perfect the second. The wheels weight much more which is bigger influence then the smaller sidewall. It now rides like a true Mercedes without having to use sport mode.
Can you post pictures of the 22" wheels, are they AMG?
I was thinking of switching out my 18" to 20" or 21" or 22" - wasnt sure on the 22" due to right and handling.
I have 2006 R350 4Matic
Old Jul 21, 2020 | 10:14 PM
  #78
Jacob Miller's Avatar
06 r-500
My 06 r500 has a drain plug for the oil but no dipstick
Originally Posted by JonMac
I believe it's all done from the top .. ie. suction out the oil. Definately the oil filter is at the top of the engine (drivers side up front, quite easy to spot).
There is no oil drain plug at the bottom if i recall my checking on this myself a few months back.
yes
Old Nov 1, 2021 | 09:34 AM
  #79
scrubber's Avatar
2011 R350cdi 2013 Viano 2.2cdi
Originally Posted by gforaker
I bought the car more for hauling ability rather than less frequent 6 passengers. I typically transport big loads of sails and gear back and forth to the boat and even a 6 ft step ladder for when the boat is hauled.
I loaded 2 upholstered easy chairs over the weekend (one was a recliner) and found out that some items which can not quite fit into the back through the rear hatch can more easily fit into the back through an open side door. (Of course, with the seats all folded down.) The rear hatch is much smaller than the interior space, but the side opening is larger or at least taller.
Had this issue with a large rabbit hutch, it fitted in but wouldn't go in, had to dismantle slightly and once in was able to re mantle to stop it being damaged, too lont to get through the side door.
Old Nov 1, 2021 | 09:37 AM
  #80
scrubber's Avatar
Originally Posted by marc hanna
When in reverse, adjusting the passenger side mirror down to point at the curb will cause it to go to that position every time you put it in reverse.
I cant get mine to do this
Old Nov 1, 2021 | 09:45 AM
  #81
scrubber's Avatar
Thanks for the summary. I have a few remarks about a few.
1. This seems to only occur if you have the rain sensing wipers left on at startup. I have an acquaintance with an E350 and his front wipers do a startup sweep if he leaves them on.
2. I tried this on my 2010 and it does not seem to work that way, at least for the newer models.
3. This works, but I think it works off of infrared so you have to stand by the drivers door and point the end of the key at the door. You can see the infrared sensor on the door.
4. Very few newer if any new models have headlight washers installed. I think it used to come only with the HID lights, but no longer. I don't have HID so I could be wrong.
Headlight washers are required in the Uk if you have HID headlamps, as is self leveling or auto adjusting headlamp aim.
Old Nov 1, 2021 | 05:09 PM
  #82
gforaker's Avatar
2015 Audi S4, 1982 Fiat Spyder, 2010 R350, 2013 E550 Cabriolet
Good point. I think the US also includes washers with the HID system. Unfortunately, I don't have the better lights, just halogen.
Old Dec 19, 2022 | 04:04 PM
  #83
f360racer's Avatar
2007 AMG R63, AMG E63
RainX works wonders
Originally Posted by efzauner
I just tried a bottle of RainX for all my cars! amazing stuff! really makes widowns clear in rain.. not sure how long a coat will last but its cheap!
Best to clean all the windows with extra care and the treatment will last longer. Use 00 steel wool after normal cleaning and they almost don't need RainX. The extra effort is what makes the water bead off better. RainX fills the microscopic craters that are inherent in glass albeit microscopically. I have been using RainX on every jet I flew that the windows open. DC-10, B-727, C-130, C-141 except the 747 as they don't open. Just applied to the windows. You didn't know there is a warning in the window frames so pilots don't forget to close them... Best auto or aviation product ever that works exactly as promised.
Old Jan 7, 2026 | 12:36 PM
  #84
psbenz12's Avatar
2006 E350
The piece in between the two front cup holders has a bottle opener on the bottom of it.
I can only assume the thought here was that a family packed in for a road trip will cause you to need a beer on the drive.
