Transmission won't shift with rocker switch?
Left is downshifting
Right is upshifting
You would be hard pressed to discern a 6-7 upshift and if you're already in 7 the right switch will indeed do nothing.
The system isn't going to let you hurt anything so if you're at high revs already it isn't going to let you downshift.
This paddle (not pedal) shifting is mostly for amusement but does come in handy in mountain driving where some engine braking can be useful. Also, sometimes is nice to just stay in a particular gear, on snow, e.g. Yes, putting the trans in a particular gear with the paddle or rocker switch (depends on year) means the trans will stay there until you manually change it with another switch press.
Ikchris is right.
No, they are not the same thing.
If you are on 3rd gear and press left side rocker switch, it will shift to 2nd gear or down to 1st gear and if you press right rocker switch, it will move to 4th gear or up
Hold right switch for 2 second or so, it will shift to auto or 7th gear (D).
On my 2008 ML350 however, the buttons work differently. The left is downshift and the right is upshift only. They each have one function. These are not rocker type buttons in the sense that "rock" from one side to the other. They are simple buttons with one contact.
In short, everyone is correct. The OP however asked about MY 2006 and yes for that model year R class (and 2007 I believe) the two buttons are identical. Perhaps MB changed the buttons on MY 2008 and beyond? Maybe they used that "other" type of switch on GL models? (this is for lkchris)
