airmatic schematic please!!
The system is very sinple. There is a sensor for the height. 1 or 2 in the back, 2 in the front. If any one of the sensors call for air, the compressor turns on and the corresponding distribution block port(s) open. If it needs to purge air, the ports open but the compressor turns off
The only mechanical parts are:
There are (2) orange 40A fuses in the fuse box
There is a green relay
compressor
Exhaust and muffler for the compressor
Distribution block
3 or 4 sensors
The tube between the distritubion block and the compressor
The tubes that run to the airspring
The air springs.
The only other compoenents are the electrical control systems. Any diagnostic of that will requrie the tester
Your trying to make more of the system than there is.
I have been told there is an "elevation sensor". This item has a part number 6511180100. I would like to locate this senor and see that it is not unplugged or visibly damaged. there are also 4 wheel level sensors. Can you tell me where this elevation sensor is please?
My car was one time sitting too high because the dealer forgot to bring the suspension down using the STAR computer after the replacement of my airmatic compressor.
If the leak is in the rear, replace both airsprings. It's very easy and takes a bout 1 hr with basic tools. Arnottindustries.com sells them for arround $170 each. If its a front corner they are about $600 each and a lot more work.
The airspring is just like a shock absorber. They need replacement just like a shock absorber. I would not recommend the MB replacement, they jsut don't seem to make a quality bladder.
I've seen some threads about a repair kit for the leaking bladder. No clue what that is about. Npo clue if it works.
While you are fixing it, replace the airmatic relay. Its about $20 from the dealer; green. It's the 2nd green relay from the left in he main fuse compartment.
You really need to fix it soon. If you don't you will eventually burn up the compressor. In my opinion you will also introduce moisture into the system which I think is the cause for the distribution block failures. The relay will likely eventually stick open or closed; the latter will burn up four pump. The leak will eventually likely burn up your pump; you'll start to hear it the pump running hard
The fronts seem to let go a lot sooner than the rear. That makes sense since the front is much heavier.
I'm not sure if a front end alignment would be necessary; there is an upper and alower control arm. The strut connects at the top to the fender landing and at the bottom to the control arm. There is a really good thread on the site on how to do the work. There is much more effort involved and you have to deal with the anti-sway bar so read the whole thread. It seems if you disconnect both ends it makes it easier.
The fronts are about $500 ea. You only save about $100 if you just do the airbag. I don;t know how you would just do that so i can;t speak to it. For the $100 you get a remanufactured strut too. Remember, this is a shock absorber. Its consumable. Depending on your mileage, the strut may not have a lot of life left. The dealer did the fronts on our R so I don't know how hard it is to do
One more question for someone. If I do replace the fronts, will I need to have the dealer calibrate this darn system? I see other post about different heights and stuff where the dealer has to calibrte/program the system at times.
One of the issues with the MB bladder is it gets hard. When you replace the rear bladder you will find it to be hard and inflexible. The new Arnott unit will be very soft and pliable. Mileage is part of the problem, time is also part of the problem. Once the bladder hardens it becomes more susceptible to cracking/abrasion and leakage.
If you want to take a stab at finding the leak.... Raise the corner that is falling by the frame, not the control arm. This will force the bladder to extend and the car to depressurize the bladder (this is part of why the leak is hard to find). You'll see the wear and pitting of the bladder at the fold when you raise up the vehicle in the earlier step. Put something under the control arm and lower the vehicle so the control arm simulates the tire loading. This will cause the vehicle to want to rise. Open the door to wake up the vehicle and it should start to pump up. Spray the bladder with soapy water, particularly at the base of the bladder where it folds over. You have a 5000 lb weight sitting on a bladder; leaks get masked by the bladder movement and sealing against metal of the folds changing. You could also cheat and disconnect the sensor, but i personally would really shy away from that.
Recalibration is not reqjuired when you replace the bladders. Replacement/removal of the sensor WILL require recalibation.
