R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
2012 R350 Right side headlight won't turn off
Old Aug 1, 2014 | 12:04 AM
screighton's Avatar
CLK500A
Got home today and noticed on my wife's r350 the right side headlight was still on after my wife's car had been off and parked for a few hours. She had it detailed earlier today, and I'm afraid they did something to mess it up.
Any advice on how to get it to turn off?
Ps. This is not the DRL system, all the other lights turn off after 10 seconds from the car being turned off.
Old Aug 1, 2014 | 02:17 PM
starbound01's Avatar
R500
Did you check to make sure it is in AUTO?
Old Aug 2, 2014 | 09:28 AM
screighton's Avatar
CLK500A
I have tried it in auto as well as 0 which should keep them off and only turn the daytime running lights on while the car is on, but it is staying on while the car is turned off... I've also turned off the lights off delay.
Old Aug 3, 2014 | 11:09 PM
R500
i'd check to see if the relay is sticking
Old May 24, 2020 | 11:16 AM
jugarcal's Avatar
R300
Hello.
I just having the same problem with my right bixenon headlamp.
How did you solved it?
What fuse can I disconnect to turn it off and save my battery until I found a solution?
Thanks!
Old May 27, 2020 | 07:05 AM
jugarcal's Avatar
R300
can't solve it yet. Help will be wellcomed.
Originally Posted by jugarcal
Hello.
Thanks!
Well, I tryed all the fuses and relays I faund and nothin happens.
Finally had access to the xenon bulb and disconnected it. Then the xenon light wen't off (of course, it's not magical).
I started the engine and I was there is NO ERROR in the display. Disconnected bulb is not detected by the system, so I think maybe the problem is the ballast.
I need some instructions to dismount the whole headlight (remember, it's a facelift R300 with Bi-xenon) and then see what is the ballast reference and try to get it somewhere. I saw many of them even on Aliexpress and Amazon, but I need to be sure about the reference number.
PS: it seems the "bad" ballast has drained itself all the battery in one night.
Regards
Old May 30, 2020 | 10:36 PM
lkchris's Avatar
'10 CL550, '12 GL550
When strange things happen electrically, suspect the front SAM has gotten wet. It’s under passenger seat and could have been soaked by your detailer.
Old May 31, 2020 | 06:46 AM
jugarcal's Avatar
R300
Is normal warer enter in the SAM?
Do you think is usual find water inside the SAM? Where did it come from? Bottom of the car?
I will try to access to the front SAM tomorrow (I has been just operated of my knee a week ago and I’m not 100% operative 😅.
Do you think is possible to open the SAM itself and try to clean the rust up with 0residual cleaning fluid and let it dry?
there are any “changeable” discrete component to change inside? (Triacs, transistors, capacitors?
(I’m experienced in sensible electronic repair works)
regards
Old Jun 1, 2020 | 01:05 PM
jugarcal's Avatar
R300
Talking SOLVED
Hi Kent.
PROBLEM SOLVED thanks to your help:
The problem was in the front SAM under the co-driver floor. Somekind of miscontact in the connectors.
As soon as I touch the connectors, the xenon headlight went off .
I unpluged all the connectors (engine contact off) and I cleaned it with Zero waste fluid and now everything is ok.
There was no rust there, everything was clean, but I felt somekind of humidity under the floor matt.
In this space under the floor, I found a little battery (sealed lead acid). I don't know what this battery do.
Regards
Old Jun 4, 2020 | 09:03 AM
B34chBum's Avatar
R320, Astro, JSW, ST4
That little battery is the power source for actuating the transmission park reverse drive.
Fail-safe power so car can put itself into park, or you can take it out of park if main battery fails.
