R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Fixed: R350 has power, starter will not turn over
Old Sep 24, 2015 | 12:31 PM
yellafella's Avatar
R350
Good morning all,
I wanted to share a fix that only took the dealership 24 days to find and fix.
Original issue:
  • Car wouldn't start but vehicle had power (new primary and secondary battery installed 1 month earlier)
  • Locks, rear hatch, lights and radio all worked but the starter would not engage to turn the engine. Turn the key and no action except the throttle body actuators
Resolution:
  • Dealership diagnosed and replaced starter
  • Vehicle worked for 1 day before issue reappeared
  • Dealership towed it back and worked on for 24 days and found the root cause
Root Cause:
  • Master technician finally traced the issue by examining the wires from the battery outward
  • The cable from the jump points (the points in the engine bay used to jump start the car) that connects directly to the starter was shorting out and sending too much voltage --> This caused the starter and the replacement starter to burn out
I'm so glad to have my car back and that they were thorough enough to find out the root cause of the problem. Luckily, I had a brand new loaner to drive around for almost a month. Now I don't have to worry about my wife and son getting stuck somewhere.
Old Sep 24, 2015 | 09:06 PM
efzauner's Avatar
2005 C240 2011 R350
The explanation makes no technical sense. The starter gets full battery voltage thru the starter solenoid. How can a short cause "too much voltage". I would like to see the explanation on your repair work order.
Old Sep 25, 2015 | 11:31 AM
marc hanna's Avatar
2023 GLK250, 1987 560SL
Sounds like a strange explanation to me too.
Old Sep 25, 2015 | 02:55 PM
josworth's Avatar
2006 R350
It would make sense if the starter was getting full amperage, but not voltage.. The 14 or so volts a fully charged battery sends would not burn out a starter... but ... if there was a short that sent the full amperage from the battery to the starter that would burn up the starter motor... and if that was the case the OP is very lucky the starter acted as a fuse. That kind of short could very easily also start a fire.
I too would like to see more information on this. May have to inspect some wires during the next service, just to be safe.
Old Sep 25, 2015 | 09:10 PM
efzauner's Avatar
2005 C240 2011 R350
Your explanation makes even less sense and is totally ignorant of ohms law.
A battery is a voltage source, not a current source. A load will draw current depending on ohms law. A starter motor does draw huge currents, 100 amps or more, and will burn out eventually if you turn it over way to much. But you will probably kill the battery before.
when the starter is activated, you basically have a direct path between the battery positive, thru the starter solenoid (this is just a big switch) to the starter motor coils, to ground, then back to battery negative. Very low resistance, huge wires, no fuses. If there is a short from positive to ground somewhere there may be smoke and fire. Yet not always. I had a short thru the alternator in another car and it is surprising how much current the large wires can handle.
So again, all these explanation make no electrical sense at all.
Either the dealer is trying to bamboozle you with tech talk, or they are trying to explain something complex in layman terms, and have failed miserably. Hope its the latter!
Old Sep 25, 2015 | 09:53 PM
marc hanna's Avatar
efzauner is correct. The battery doesn't push amperage, the starter draws it. The battery pushes voltage so to speak.
something fishy going on.
Old Sep 26, 2015 | 06:00 AM
efzauner's Avatar
2005 C240 2011 R350
It could very well be that the starter was engaged for a long period of time due to a short, but that this took days to diagnose is puzzling.
Old Sep 26, 2015 | 07:15 AM
marc hanna's Avatar
Well, these starter systems are a little more complex, not the traditional simple electric system, but rather an electronic system. So they were probably searching around to see if some other electrical or electronic device was blocking the start sequence.
Old Sep 26, 2015 | 09:17 AM
efzauner's Avatar
2005 C240 2011 R350
Marc
actually from the original description , the problem is isolated to the 12v power and ground system from battery to front jump terminal to starter.
Looking at the wiring diagrams from ALLDATADIY ( I also have MB Star system data base) there are electronics, but ultimately there is one module that sends a 12 volt signal directly to the start relay in the front right fuse/relay box. This relay then powers the starter solenoid (which is an integral part of the starter) to close contact and power the starter. The solenoid has a direct connect thick wire to the battery/front jump terminal. Return is via chassis ground. No fuses here! The wires are well protected, very rugged and in my 40 year home mechanic experience rarely cause a short. Most problems would be corroded terminals causing an open or high resistance.
Conceivably there could have been a short in the fuse/relay box wiring that caused the starter relay to close intermittently, or stay closed longer, causing the starter to activate. There may not be any damage to the control wiring because the electronics module is normally protected. But it would be very obvious that the starter was engaged. Excess use would cause it to overheat and burn out. Remember that the solenoid is either open or closed, there is no way to send only partial power to the starter. The other possibility is that a short would cause the starter relay to malfunction and NOT send power to the solenoid. But this could hardly cause the starter to burn out.
So unless the OP has more detailed info, such as part numbers that where changed, I am halting this wonky wild goose chase... Lucas electronics in my first drive, an Austin Marina, comes to mind!
Have a great weekend!
I am going to pressure wash my R350 engine... and that's all because I still don't have plates... bloody mess at quebec licence office.
Old Sep 26, 2015 | 04:24 PM
marc hanna's Avatar
Your assessment of the situation sounds fair. I haven't dug into the starting electronics on these because I've never had a problem with on e before.
Hopefully the OP can update us.
Old Dec 5, 2019 | 06:07 PM
ski518's Avatar
2011 R350
Yeah, I developed FoMoCo's Electrical / Electronics Courses, plus have a BS in Auto Engineering, taught Electrical / Electronics to all the ASSET instructors in North America and at Weber State University. mmm, one could say these guys installed a starter on a vehicle, which may or may not have needed one. I have no idea what fixed your vehicle, but a short on the rock & roll side of the starter circuit may blow a fuse-able link, but will not damage the starter. If the starter was damaged, something else caused it. Again, don't know what fixed it. I would have to speak to the Master Tech. Bad terminal? t could have been the ignition switch/module? This is weird timing, but I should share with you. I visited a friend's shop two nights ago, I see an ignition switch / module, (like yours) , on his bench and it was replaced to resolve the same concern you had. Now, I must say starter motors "burn out" due to age and they will go bad over time. So, it's replacement may have been warranted.
Old Dec 15, 2019 | 02:12 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
The cable from the jump point down to the starter are a known problem for corroding inside the plastic cover and not carrying full voltage to the starter motor. The result is either a slow crank or no crank at all. Ask me how I know lol
Old Mar 26, 2023 | 10:16 AM
Yemiii's Avatar
Rclass
Just went through the starter saga
can you guys post how often have you replaced your starter?
mine so far is 3rd starter in 10yrs
we have other brands in family fleet at the same period and usage is basically equal ..never starter issues
Old Mar 26, 2023 | 04:36 PM
efzauner's Avatar
2005 C240 2011 R350
wow, Nice to resurrect old threats. And wow, did I spend time researching this one back then!
I have never changed a starter in what.. 62-16... years of driving.
Old Jul 20, 2024 | 07:12 AM
Alkebulan's Avatar
2007 r350 w251 m272 722.9
so what is or are the code/the codes that usually associated with this issue?
Old Today | 04:28 AM
Prerna's Avatar
2008 R500 5.5 l
Mine is sometimes very weak when engine is heated, I think it's time to replace too. Is it a big job to change it..?
Old Today | 11:01 AM
Yemiii's Avatar
Rclass
What is engine heated? Do you mean when engine is at operating temperature?
Starter not spinning fast could be a weak battery or even bad connection
The problem is getting the starter motor out after removing the bolts. Not enough room between the engine and the body frame, loosen the mount to tilt engine to create space
